Root CyanogenMod 7 Unofficial Beta 5 02/20/12
so if im using morphs or cm7 themes i shouldnt use this?
CM7s theme chooser just interupts the system when it goes to get a resource from the apk and says use this one instead. u should be able to use the theme chooser with that mod, and as for morphs ull just have to add em after u flash the mod
Found a issue not sure if anyone else has experience this when my phone is on "Vibrant" mode or w/e when I get a text or anything it doesnt vibrate at all
Here is a fix! my first mod!! thanks too hroark for makeing me brave enough to boot loop my phone! lol this one works.
Fix for Roaming Indicator
THIS is for the stock rom/themes from hroark, do not install this if u are useing a custom theme as it will mess it up.
i edited the strings.xml and the eri.xml
and used one of hroark zip files to make this flashable
thats what i did but it wont boot. i think i know why tho. i had done it on the beta 1a
I am hoping to get an Official status once we work out all the bugs. we are getting closer everyday.
We can use help with making kernels, we have not been able to compile a working kernel from the Samsung source code
We have only been able to mod the ramdisk of the kernel
id love to but im hitting the same problem u guys have. if u can get it to compile shoot me a PM and i might start working on a lil sum sumin:) lol sorry i dont have much time to play with getting it to compile tho:(
Appreciate the hotfixes Hroark and the "Roaming Indicator" fix Sonic. I was even able to get it working with a ICS theme I am using. Based off what Pwn said earlier
Just make sure to switch to a default theme first. Boot into CWM recovery, then flash Sonic's zip. Should load up fine with whatever original theme you chose. Open Theme chooser, apply your custom theme and "Boost Mobile" should be in your lockscreen and notification pull down. You may have to reboot again to properly apply all assets from your custom theme.
There is only one bug I have found with Beta v2d. For some strange reason I lost the CRT animation when the screen goes off. Tried turning it off/on in Cyanogenmod Settings>Display Settings, Screen-off animation. Even tried reverting to just flashing Cyanogen Mod beta v2d and hotfixes, or just the beta itself. In beta v1 the only thing that would bug it out was Widgetlocker since it has a feature to override your Lockscreen animations with it's own. But I have not even reinstalled that app yet so no clue why it's not working atm. I do miss it however haha.
By the time I installed beta v1 we were at 17.....
Woot we broke 100+ CMstats http://stats.cyanogenmod.com/
