PhoneMan93
Have you found out what was wrong with the vibrate
First of all, thanks for all of your hard work, the community appreciates it.
I just installed the latest release (3.5) switched from CT2.3, before anything else I also installed dt_a2sd (latest version). The reformat went smoothly, booted up to check a2sd settings but the gui wasn't installed in my apps, no prob, so I loaded terminal to run a2sd check, which apparently installed fine, just no gui. I went to the market to grab a couple of apps. I was able to install, even to sd, but after every install market would fc and soft reboot my phone (back to your new boot ani).
Everything installs fine, just this reboot thing is annoying.
Any Ideas?
UPDATE: Well, looks like anything I install magically disappears...so I'm ditching a2sd..for now.
Is your sd card partitioned???? try using s2e from the market....
Will Chin Checka's A2SD/S2E mod work with this? http://androidforums.com/galaxy-prevail-all-things-root/439196-mod-a2sd-s2e-cm7.html
Hi guys
There are enough posts in this thread about a2sd and link2sd
I would appreciate if we use a different thread for a2sds stuff
If it turns out that this version has some issues with a2sd I will look in to it
Hi guys
Installed CM7 all went well but i cant get 3g, mar-ket, mail. how do i get goo-gle acc. back and 3g signal?Media Player FC
sweet mother of Jesus you are the man hroak I'm beta testing now! !! Plz keep up thegood work but also don't work to hard Xmas is comeing up ;PIs your sd card partitioned???? try using s2e from the market....
Just installed... everything works (or does not) as advertised...
However it does seem to be a problem with a2sd the ext partition is either not being mounted or read correctly...
Will report back with any other issues.
is your s2e working?
No sir, it is not... the options are greyed out and not selectable...
mms doesn't seem to work on wifi or 3g
ringtones volume still sounds like its about to blow my speaker
I also hit the mms issue... but the Rom keeps getting better.... I definitely rather trade the trade off of the wifi toggle issue for gps locking in under 10 seconds... nice!!!!!
