abrahamramirez
what apps ?
im gunna try to install adaway to get rid of the ads and i tried busybox installer and it failed.
what apps ?
great! that'd be something nice to see.
about my su problem, was it something with my install or are more people getting it? i think ill try reverting to stock and re-installing
that is a waste of time to revert to stock
the rom formats the 3 partions, and loads a kernel
the only thing it does not over write is the baseband and recovery partition
so dont revert to stock
i used wireless tether for root users and it seems fine
what root apps are you having issues with, so i can try for myself
de-odexing is need fo themeing, but with CM7, cant we just download the theme in and apk file
it is easy to de-odex and zip align apk files, but I dont know how to re-odex an apk, so you guys have that option
okay. so then ill try re flashing 4b over my current 4b insallation. as for the apps, i try to install busybox from busybox installer and i get a su error. i tried applying adaway to get rid of adds but im getting a read/write errror when applying. and when i try to update binary in superuser, it fails
mms still wont send with wifi on, is it just me or is the speakerphone very low
I just installed the beta 4 and so far everthing is looking good. This my first time on cm7 so sorry if this was asked already or answered some where that I didn't find.
I tried to install darktremors a2sd script. The official one not the one from here and I get an error when I open up the gui saying either I'm not rooted, I don't have the script or I don't have an ext partition. I was running the previal version on a ctmod before without problems. I also tried the previal version and got the same errors.
Any Ideas what I could be doing wrong?
Will this reset all my settings?
Google maps is force closing on me
