Yep, flashed using CWM. 5.0.2.7
Aborted with an error.
ill test when i get a chance tommorow and put a new one out if needed
Ok , I really don't know what I've installed that causing me problems . Last night when I was talking to a friend , I did a Titanium restore . The restore went well and the phone was running great . I went to reboot and all the apps I had restored disappeared . I rebooted and magically they reappeared . This happened several times after rebooting . I thought that Titanium may be the cause so I installed them manually the next time after a fresh install of beta 5 . Today the darn phone started doing it again . I've gotta conflict on Beta5 with the one or more of the apps I'm running , I think . I reverted back to the previous version of CM7 today and my phone is running like a champ . Same apps , same set up minus S2E on Beta5 . Gotta have my phone through the week so I'm gonna work on it some more this weekend and find out were my conflicts are .![]()
I guess it depends on what you need. I used to run Linux back in the day when one accessed the net through a dial-up modem, so I do have some experience dealing with ppp on Linux, but not sure it's applicable to what you're looking for...
Are you saying you are running S2E on Beta 5? Why???
i messed up, that zip does not have a boot image for some reason
here is a link to the beta 4 kernel
beta4d_kern_cwm.zip
the only difference between the beta 4 kernel and the beta 5 kernel is integrated apps 2 sd and the smaller modules
i will be making a new kernel soon and I will be sure to make an apps2sd version and on non apps2sd version to give people a choice
our phones uses ppp for the mobile data
my rom connects to the 3G network and gets internet just fine
when you turn on wifi, it disconnects the ppp0 interface and then the wifi interface eth0 becomes the active route
when you send an MMS when you are connected to wifi it tries to establish the ppp connection, but fails
I beleive MMS needs to go over the ppp0 mobile data interface
i think the MMS proxy will only allow connections coming from that network
i need help figuring out why the ppp connection fails when we are on wifi
when you send the MMS it should establish the ppp connection, send the mms message and then disconnect
do you know how to use logcat?
I said minus S2E on Beta5 .
In other words , I'm running S2E on Beta4 not Beta5 .![]()
Ahhh... OK! I thought so but it didn't read that way. Probably just me![]()
Then I'm not having an app conflict or card problem . It's something else . Thanks , that will save me some time . I was gonna reinstall beta5 this weekend and run a trial and error with each app . Glad I don't need to do that now .I thought it may be Titanium but I installed all the apps without and still had the same issue .
I wonder what's causing it , hroark ?
I have had a weird problem occur with Beta 5 three times.
This never happened when I was running hroark's original solution kernel with the Previous Beta.
The first time this happened I was still on my old SD card and I joked that I had had an Acid Flashback. No more jokes about this. It has happened twice more.
Basically, I reboot the phone and it acts as though a factory reset has been done, except that I have found that data is still on sd-ext.
I assume somehow the symlinks get destroyed and the system boots with the empty data partition. Sd-ext is still loaded with apps but system ignores them and uses old data partition to rebuild Dalvik for system apps only since no user apps are seen. I don't know if anything on sd-ext is corrupted.
This third time I had a very recent CWM backup. so I flashed the Beta 5 zip and restored the backup and everything was back like before.
Before I did that I played around with it a little. I just flashed the Beta 5 zip without a factory reset. The apps were still on sd-ext but I started having problems.
I actually lost all connectivity, but it is possible that I deleted something out of the system folder by mistake but highly unlikely. I tried flashing the Beta 5 kernel but that did not help.
I finally restored an old backup before beta 5 and connectivity.came back.
Then I factory reset, flashed Beta 5 and restored the newest backup. Everything good now.
What could be causing this situation where it ignores sd-ext and does a half ass reset using the old data partition to rebuild Dalvik for the system apps?
I blame Kouma. I don't know why, but he looks guilty.
My guess, and that is all it is, but I would think what is triggering it is the sd card is not mounting fast enough and so the kernel mounts to the next location.
I only have vague half formed guesses as to why its intermittent. nothing I would even put into words.
I flashed the new beta and everything was working fast but when I did the mod for the sd card my phone has been force closing facebook and a few other apps and it has been working a lot slower. Im thinking about reflashing the new beta and leaving it alone. Everything else ok.
