I just was wondering if i have installed the 3.5 beta how can i update to the 5 beta? Do i have to go the step all over again to install it?
Got it, ThanksTry b5 and ull get something more like this:
@wetbiker7
How did you change the Notification Bar?
Does anybody know of a fix to get the phone to ring more than once on incoming call?
It rings only once and thats it.
I had the same problem not too long ago and had to dig and dig to find an answer. The issue is caused when the ringer (usually a .ogg file) is missing a special tag in its "Metadata" called the "ANDROID_LOOP" with a set value of "yes".
All of the following was done with the app "Root Explorer", its the only file manager I trust for manipulating the internal storage. You could however hypothetically use any file manager allowing a the remount of the internal storage as "Read/Write".
1) Navigate to "/system/media/audio/ringtones"
2) Copy the the .ogg file your PC and download a program called "Audacity" and install it. Make sure its 1.3 beta or higher.
3) Open the .ogg file in Audacity and in the "File" menu choose "Open Metadata". In the "Metadata window" add the "ANDROID_LOOP" field and give it a value of "yes".
4) Save the ringtone file and close Audacity. Copy the file from your PC to the SDCARD and then using a rooted file manager copy the file back to it's original location and reboot the phone.
5) Go to your sound preferences and re-select the ringtone you fixed from the list.
I hope this helps!
Thanks, it does loop now but now there is a different ring before my ringtone sounds. Like, it rings once as a diff ringtone(dont know which one, sounds like a basic ring) and then ringtone i picked starts...weird.
Ill try reflashing
i had the notification bar freeze (accidentally 'tossed' a text msg to the left, lol)
lol... Thats happened to me before too and I did the SAME EXACT THING... I even pulled the battery and prayed for a minute...LMAO.... Then I turned it back on and haven't seen it since...
Hey Guys, I am using Hks beta4 hf3 and I had the Notification issue Twice and I rebooted the first time but the second time "I just slid up the notification screen and went to the particular frozen message and opened it and that clears the frozen notification, without Rebooting. Give that a try and if it works for you, it will save the time of Rebooting.This is an ongoing issue and has been reported in older post . Sometimes I can even totally throw the notification completely off the screen. I've just learned to be careful when touching the drop down notification screen .
EDIT . The only way I've found to reset the screen is to reboot .
Maps is fc-ing for me too. Not on opening, but it lags to death and asks to fc or wait. (waiting does nothing), but navigation works fine(and uses maps to do it?!)
