So I'm running an older version of CM7 and want to do a fresh start. I'm going to be doing some fresh start tests on a couple of things including Kourma's new 1.5 kernel with CTMOD. I already tested it on a working phone but would like to do some fresh starts to make sure things are working as they should. This includes updating my older CM7 install.
Anyways I just want to make sure I get this right for CM7 mod since it's been some time.
Please let me know if any of these steps are incorrect.
- FA19 Gingerbread Rooted Image with CWM5 by Koumajutsu -----> PREVAIL_M820_FA19_Rooted_CWM MD5Sum: 97b46a074e228b9daeca95a2c80715b4
- DOWNLOAD CLOCKWORKMOD 5027 UPDATE FIXED ------> SPH-M820-CWM-5027-UPDT-FIXED2A.zip
- Download latest CM7 mod from Hoark. cm-7-HROARK-beta5.zip ------> http://www.mediafire.com/?5i59286qgqxw8c0
- Download the latest hotfix. MAPS FIX CyanogenMod 7 Unofficial Beta 5 02/20/12
- ODIN to FA19
- Apply the 5027 fix for CWM5 using 'Install Zip from SD' from within CWM5.
- Install cm-7-HROARK-beta5.zip using 'Install Zip from SD' from within CWM5.
- Install the Hotfix for Maps using 'Install Zip from SD' from within CWM5.
Now I think the above steps should be correct. The only part that I think is
optional (because I'm not sure incorporated yet into the build) is the kernel version you can use. It's my understanding that there are two you can pick from.
- If you want /data to be on your SD-EXT then you have to have a partition on your SD Card. Then download mapfixkrnl-ext.zip and put it on your SD Card. Install it from CWM5 using 'Install Zip from SD'.
- You DON'T want SD-EXT but you want to have the /data mounted on the internal stl13, then you need to download mapfixkrnl-no-ext.zip and put it on your SD Card. Install it from CWM5 using 'Install Zip from SD'.
I think that should cover it. I could be wrong though and hopefully I want to get it working right before I upgrade my CM7 version.
Please let me know if the above steps are correct.
Some of the instructions on the first post can be a bit confusing.
