ninjarabbit
works fine for me too... the only little thing that bugs me is the notifications freezing when you slide them... other then that, I'm lovin it...
Works fine for me... i do have voice search & dialer installed tho....
DEEZAM! I just installed CM7.1 beta5 last night. This rom has more options than a chinese takeout menu. And I didnt even install ADW EX yet. Holy crap on a cracker
PS- Where can I find info for themes for the CM7 rom?
Thinking about it, I tested with the Google Listen app (podcasts). I will test with the music player as well.
, strangest thing started happening to me... GPS completely stopped working... Would not lock on... (crude nbl worked but not accurate enough for navigation... (at one point it said i was in the Indian Ocean )
I solved it, however, by reflashing the mapsfix kernel and all seems well now... Just can't figure out what it could have been... Also, the phone got considerably hot with GPS turned on...
i had the same issue, annoying when your lost lol
You need to install Flashplayer for your browser . Also , Facebook takes some time to load on mine . I'm running CM7 at the moment . When the screen pops up and asks if I wanna close it , I just tap wait . Even though I choose not to sync my contacts , it looks like it still does and this slows it down when loading . After the sync icon is gone from the status bar , it runs fine .
This is the link to the thread w/ Flashplayer :
http://androidforums.com/samsung-ga...rking-version-adobe-flash-player-previal.html
Thanks. I used that before as well... But in this case the gps icon wouldn't even pop in notifications, like there was no gps...When I usually have GPS issues on any mod like CTMOD or CM mod, I usually perform these steps and it fixes my issues.
- Download FasterFix from the Android Market Place.
- Run FasterFix and set your time pool to your country. Example: I set mine to North America. Then press Apply. You only need to do this once folks.
- Uninstall FasterFix
- Download GPSFix from the Android Market Place.
- Run GPSFix and place the android on a flat surface for a few minutes. Like a table or something. Make sure it has good reception for the GPS.
- Let it do it's single and dance until it's done. When it's done click on 'Start Fixing' again. The goal is to make the app Fix the location as quickly and instantly as possible.
- Eventually it will fix the location pretty much instantly the moment you hit 'Start'. When you get to this point your done.
- Uninstall GPSFix
Congrats your GPS has been fine tuned and now works flawlessly. I've done this every time I've ODIN'ed my phone and installed a mod from scratch. This includes countless versions of CTMOD and CM. t works for me every time.
Enjoy!
