Root [DEV][ROM][ALPHA][WIP] CyanogenMod 10 for the LG Esteem 4g LG-MS910
I just installed it just to see if it works. The phone ril isnt apart of the list unless you can use a different ril but i dont think you can.
google is about or already to released open source for 4.2 and CM team is ready to work on it... if you know what that means :).
Yeah but they wont make it for our phone otherwise we would have it made already. Besides pg is doing one hella of a job
4.2 has already dropped, I have src and have it on my GNexus ;)
CM is still replicating and should be merging later on tonight ;)
I have 2 esteems so I can try it. ;)
If ya break it... can I buy it? :)
After I threw my esteem...
I forgot to clean the big thumb print off the backside of the digitizer as I preceded to crazy glue the bastage back together on my smoke break at work :)
Plus the back light is screwy and the soft keys don't light up no no.
Whoops
getting status 7 error. how do i fix that???? been lookimg on how to flash a rom n iseen this really want to test this out as noobie
I think it always was alpha. You should check the playful droids wiki to know if any changes have been made.
Edit: Always helps to check the wiki
The wiki is always the best place to get up with anything I do. I update & post on it b4 I do anything else.
When I go to the "performance" section my Max clock speed is 1.2 GHz. Is this a bug or am I missing a kernal DL? Also, is there a face unlock option in the ROM? Not asking for it just asking if it's in to play around with it a bit :3
