for you and me n others its easy peasy, to others its rocket science, like following written instructions for some.....
Well, since we were talking about Linux Mint i was recommending the Mint Windows Installer but whatever us easier for everyone else.
if so, thanks i appreciate it, if not than thanks anyway, i still appreciate it lolthe link is in here some place lol.hey pg what are the chances of me getting a copy of this? i dont want to brown nose and say i can help & test or anything i just want a good CM9 rom (preferrably that works on our device) so i can take a peak at some of the xml's and see what i can port over to our roms or any 'ics' specifics i can add to the ld-ick themeif so, thanks i appreciate it, if not than thanks anyway, i still appreciate it lol
haha o github... i never understood how to use itthe link is in here some place lol.
if you just wanna look at raw xml's check out my github![]()
haha just noticedHappen to check the first post for a link?![]()
lol thanks buddownload the link in the first post of this thread and it says status 7...any way to fix this?
).well i got it fixed...but have a question...what is the difference with zva,zvb,zvc,zvd and which one is the best to use..
What is that link to???
:thumbup:
There different versions of our software. C, D were trying to fix the reboot issue. Zvd fixed it and it's the best one on my opinion and most of the others here on af.
Not sure how this relates to the status 7 issue?
Can you clarify / elaborate? (I'm not seeing the connection...).
Thanks!
