Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Also HUGE tip if you are stuck on orange twrp and flashify wont work just flash the new twrp with the twrp you have using IMG flasher on the bottom right corner in the orange twrp. Just put the new twrp on a SD card then flash boom new twrp
I'm not sure what you mean? Why would it break camera? The reason is to keep updated from upstream.
All I get from camera app, granted this is Camera FX, but stock camera does it too
Quick question guys. Ive read a couple places that there is a script that can be downloaded and ran to fix the battery issue with Cm12.1. Or at least partially. I was told to look in the Lg leon rooting section, but cannot find it. Could anyone send me or post a link? Thanks guys!
It's under Root-LG Leon. It's made by @Bichofelix I believe. I would post link but I'm not sure if he'd like me too. I'd rather be safe than sorry.
The script doesn't do much to fix the battery percentage, its a combination of using the script and Power Save mode under Settings > Battery then the battery percentage will sorta tick down appropriately when the screen is off. That's what I understand of it, but I've been told wrong multiple times by @Bichofelix so hopefully hell clarify. I've tried it but I just can't seem to get the results he's posted. Either I use my phone too much for the difference to take effect or I'm just an idiot...banking on the latter.
The thread is quite plainly labeled "Script"
Just to fill you guys in, xposed does work, and I'm using the Xposed made for 5.1.x and it's great. The only problem I've had so far is Xprivacy causes random reboots. Just wanted let you guys know that, so y'all don't have to find out yourselves.
Anyone who wants to reboot but hates the battery bug enable advanced reboot than use soft reboot it doesn't full turn the phone off but say you installed v4a and needed a reboot use soft reboot without triggering batt. Bug
Herr's the next build of the new kernel https://www.androidfilehost.com/?fid=24052804347789077 imported lge usb changes and vidc changes should take care of the camera issue and usb/charger reboots.
Warning to everyone running the 345H: This will brick your device!
It just gets stuck in a bootloop on the LG screen. Also the "Cyanogenmod" battery indicator will no longer show up. Fortunately, I was able to get back into recovery. Any ideas?
When you say "345H," do you mean the h345 from T-Mobile? I have the h345 and flashed the kernel and everything is running like it should. I flashed the kernel with flashify.
T-Mobile here too. I also used Flashify and except for the camera there were no issues.
Yeah, I did. Blame it on no coffee. I tried right from TWRP, so that might explain it. I'll give Flashify a go.
Edit: Still no dice here. CM flatly refuses to want to boot with this installed.
I my self had this problem flash it if it doesn't work flash it again ur last option should be factory reset then flash
