Root [DISCONTINUED][ROM][5.1.1][MS345] Unofficial CyanogenMod 12.1 for LG Leon
Does anybody have a link to the proper blue TWRP needed to flash the 5.1.1 ROM I have no OS am rooted with su stuck with yellow TWRP. Could I flash the blue TWRP needed to flash cm 5.1.1 from the yellow 2.8.7.0 TWRP? Thanks in advance made a nandroid yellow TWRP wont recognize either weather I rename it file or not so this would be my only shot to get this phone going with an OS as far as my case goes since I have yellow TWRP, no pc, no os.
ya I cant use flashify I have no os going all I have is su root and yellow TWRP 2.8.7.0 I think what I want is .2.8.6.0 but I can only do the flash from the TWRP I have being stuck with no os or anything
naw I figured the same thing but cm wont flash from 2.8.7.0 and I dont have a pc so looks like Im screwed if nothing flashes from yellow 2.8.7.0
,Img file a? do you have a link? I just tried a zip and it flashed I tried it frim ext and int sd card but it just booted back to yellow TWRP img file a? so is there a link for the file. I guess I will start by googling thanks man
I got u man heres link https://www.androidfilehost.com/?fid=24052804347772357 this is the twrp u need this is how u install it and replace it the yellow orange kinda one once u download it boot in to the recovery u have the yellow orange one to do that u turn off ur phone once off you press power button hold it then volume down while still holding power hold both buttons till u see lg pop up then u let go then press them again the same way exact way again like I said before with power and volume down tell hold it then say factory reset put yes than ask you again put yes boot to recovery once in recovery click on install on the right bottom corner ull see flash IMG I'll recognize images go to downloads and flash recovery twrp ms345 if it say ms345 its right one then click it and I'll say boot or recovery put recovery then flash then reboot to recovery again there u go u should see blue lollipop sorta recovery like if I helped
ya I got they keypress down on all LG phones I have an F6 Ive learned alot on. but ok Im headin Im gonna click on the link thks by the way be so sweet if this all works and I end up with 2.6.8.0 TWRP ms345. So if it goes & I end up with blue TWRP I can flash cm 12.1? thats what you all have been running right?
the link you provides takes me to the 2.8.7.0 yellow. thats the one I have and am needing off
No its the blue one trust me the yellow Start's with c50 this one was say ms345 which was created by unjustified dev for this exact ROM cm12.1
thats the one I flashed with flashify when i first started hmmm well ok I guess I'll flash the one from youre link its 2.8.7.0 ms345 right but it will be blue this time from youre priovided link? just double checkin
Ya flash with the twrp the yellow one don't use flashify
Thats just it I cant use anyrhing but the yellow twrp to flash anything I have no operating system no os. And now Im confused I have yellow 2.8.7.0 yellow TWRP I thought I needed blue 2.6.8.0 TWRP in order for it to recognize cm and whatknot? so anybody who knows wich TWRP is needes to flash cm 12.1 properly plz fill me in and thanks Im getting condradicting advice I been googlin all over the place link hoppin and all I got was Im on yellow I need blue & this is all I have to work with the phone Im on my F6 and my obvious Leon wich is su rooted but Im stuck with no system at all nothing 0 Rom I can keypress into yellow TWRP. I was told I could flash blue TWRPS image file from inside yellow TWRP now if that isnt possible and I cant flash aquat from yellow 2.8.7.0 than why is this TWRP anywhere near the leon threads? hmmmmmmm lil confused here
Flash the blue twrp I gave u with the yellow twrp u have then reboot to recovery again and u should have the blue twrp
I have it says its wrong firware Im on 5.0.1 this it says its for 5.1.1 when I flash it. hmmmm but yellow 2.8.7.0 is the right TWRP? I was given the advice to switch to a blue TWRP 2.6.8.0 to get cm to flash..... ya Im gonna leave yellow TWRP and await some better knowledge out there or somthin. Maybe a rom that flashes for yellow TWRP will come out idk. thks for tryin to help me though man Im just getting bits of alot of different info on wich TWRP Im suppose to have and how to run/flash cm 12.1 and what my options are from my standpoint of no os but yellow 2.8.7.0 Twrp and su root. no pc, just the phone Im on to maybe download anyrhing I might be able to download on my sd card and pop in the leon and flash using yellow TWRP till I know for sure which TWRP I really need for firmware 10b metro PCs LG Leon ms345 and if I should stay on 2.8.7.0 & more importantly can I flash a file or zip from 2.8.7.9 yellow TWRP to get me runnin this phone at all, not having a pc to ADB kdz or anything is my biggest issue. thats why Im tryin for options of TWRP cuz so far yellow TWRP isnt flashing CM and I was told it wouldnt youre I want 2.8.7.0 So Ya idk. thks tho man I hope you take no offense I appreciate you even takin youre time to try and help me. But just so its clear for anybody who might have the right workaround for my spacific no OS, No pc, rooted with su zip with 2.8.7.0 TWRP recovery untill confirmed if I even can and to either switch TWRPS by way of flashing from TWRP/Yellow as of now, and/or a rom for firmware 5.0.1 comes out if at all or somthing I can do to get up.and runnung from TWRP 2.8.7.0 IF even possible. THANKS AGAIN EVERYONE.
hey man thanks for ur hard work I'm not trying to demand a anything or be greedy but I'm going to tell you that your new kernel sometimes gets me stuck on bootloop plz fix thnks man
It wasn't meant to be stable and used by users only for people willing to test and help me debug the issues. You should flash back to original boot.
