Do you have the new market installed? If not it's probably that.
What is the new market update?
how do you know if you got it or not?
I am running Velocity .3 and Overclocked at 729
Then you don't have it.
lol, also swc, go to the app info in settings/applications/manage apps and see what version it is. It should be 2002012 for the new one...or open up the market, is the bag icon 3D or flat? If it's 3D then it's the old one.
Well it says I am running version 1714 I think and I have the 3D bag.
Soooo How do I get the new market? Do I need it? What does it do?
I just went back stock and took the update. I now have ZVC
However I flashed my Nandroid back to velocity.
So thats where my phone is at the moment.
Download from here:
MEGAUPLOAD - The leading online storage and file delivery service
After it's downloaded, find the file in your SD, press on it and hit open app manager, then install (assuming you're using ASTRO).
It's a really good idea to uninstall the old market first
Settings>Applications>Manage applications>Market app (probably com.market.etc.)>Uninstall
Download from here:
ok Sounds great..... Whats it do for the phone again? Any cool perks?
Or is it just different?
You can't uninstall the market from settings/applications, it's a factory app that has to be un-installed via terminal/shell.
You don't need to uninstall the market, the new one is an update of the old one, it's applied over whatever version is already in place, just like any other app.
Not really, just a new radio. You may notice a better signal.
Wait a minute I thought this was a new Market not the new radio from the update zvc???
I installed this new market.... nothing Remarketable about it so far.
