anthonypaige
Member
Artine I have what may be my last question. Will my apps I downloaded from google play still be on here
Oh your Brilliant I have been sitting in dunkin donuts for almost 4 hours preparing both me and my phone for your rom and its finally time as soon as I finish the download.
I've just finished uploading the newest build about 5 minutes ago. Try downloading v2.0.9Ac from either DevHost or Mediafire (the links are in the OP).
First off when I install the rom at first everything was fine. However when I went to run app called lane splitter it would run extremely slow and then eventually my phone just rebooted itself. I tried once more to run the app and I reach the same result. To make a long story short I had this same issue with overkill, temple run and also another app that I can't remember the name of at the moment. The ROM that I am referring to is Sleipnir 2.09. That is basically the main issue with the ROM. There was another minor issue that I had with the wifi after first installing the wrong it wasn't working when in the Google Play Store when trying to download an app. It kept saying error downloading..... but I'm not sure would consider this a major major issue because it seem to fix itself once I got my gmail account setup. now I know you guys are probably thinking who's this guy to talk because I'm new to the website and the lg optimus Elite for that fact but I actually have a lot of experience with the LG Optimus One. now this is just an opinion but I believe that the ROM should have a couple of a couple more preloaded apps with it
Working on getting my 4th Elite setup with CWM. Which of the .bin files was the version that used the time fix?
I liked it better than CWM 6.
Its been over a month and I haven't seen any huge bugs mentioned. So today I whipped up a noob-friendly installer for the CWM. I don't have any screenshots, or instructions because its just 1 button. Download LGOE_NoobTool-debug-unaligned.apk from Sendspace.com - send big files the easy way
Requirements -
Its built against the latest Necessitas, so you'll need Ministro II from about Nov 22 or newer. If you have installed an older one, you can delete it and get the latest one from the market. https://play.google.com/store/apps/details?id=org.kde.necessitas.ministro&feature=nav_result#?t=W251bGwsMSwxLDMsIm9yZy5rZGUubmVjZXNzaXRhcy5taW5pc3RybyJd . If you don't have access to the market, there's link to it here http://files.kde.org/necessitas/installer/release/Ministro%20II%20v8.9.2.apk . The CWM installer will spit out an error and catch fire if you try to use an old version.
This installer uses the backlight exploit. If you have a kernel where that bug has been fixed, this installer won't work.
As usual, its only been tested on my phone. I offer no warranties, use it at your own risk.
thanks for the thread Artine. it helped me figure out some stuff to achieve root for the first time.
i used poot to root, then i used Giantpunes noob installer to get CWM, seen here:
then i flashed a ROM and i was pretty much all set. (i did add a few apk's for calendar and livewallpaper, with some help found in various other threads).
all very easy and quick to do, i did it all on my phone. easier than i imagined.
thanks to everyone involved with getting all of this stuff worked out. great work.
When was this made a Sticky? xD
I have to send my 4th Elite back to VMU and I was hoping someone could help me by uploading a copy of the install-recovery.sh from /system/etc for me so I can remove CWM from it.
I've made a couple of changes worth noting - and they're mentioned in the changelog as well. I've added giantpune's noob installer to the FAQ-Guide, and another method to entering Recovery. Also, I've begun the planned overhaul.
If he pm's me his email I can email it to him. I only have my phone so I can't attach attachments. But I have an old nandroid of my stock rom and it had my "install-recovery.sh.bak" in it and I extracted it with Nandroid Browser. Now sitting on my external sd card waiting. :] It's a ZV5 Nandroid. But I do believe I made the nandroid before the Zv5 update so I'm kinda lost on ehether it's zv4 or zv5 lol.
Correction: Zv5. Just checked the build.prop so didn't you say that file isn't present in ZV5? How come I had it? The Nandroid I have for my stock rom is from before I did ANYTHING. I installed cwm, renamed the file, and backed up my rom. And I was on ZV5.
I have followed every step correctly without any bumps or errors until I go to try and load cwm by using Quickboot's recovery option. I have Sleipnir v2.1.2 on my /sdcard, and I have successfully created a nandroid backup using cwm the first time it loaded. The only exception this time is that when I boot to recovery the page looks different. It reads from top to bottom (the second half is in yellow)
"Android system recovery <3e>"
"Android system recovery utility"
"Reboot system now
Apply update from sdcard
wipe data/factory reset
wipe cache partition"
"Finding update package..."
"Opening update package..."
"Verifying update package..."
"E:failed to read footer from /cache/ (Is a directory)"
"E:signature verification failed Installation aborted. no valid image in
CACHE."
"Check sdcard for GOTA update : /sdcard/update.zip"
"Finding update package in sdcard..."
"no image found in sdcard"
"E:failed to open /sdcard/update.zip (No such file or directory)"
I would appreciate it immensely if someone could help
First things first, between the Nandroid backup and rebooting into CWM, did you wipe/format/erase anything? And what about prior to the Nandroid backup?
Before the Nandroid, I wiped cache partition and dalvik cache as the instructions for the backup stated. After that I rebooted, and placed a ROM onto my /sdcard. I then tried to reboot into recovery to load cwm, but that's where I'm stuck.
