Special bars, huh? Are these like special brownies my friends used to make?![]()
No, they're called Access Bars, not available in stores. 40+ patents. They actually trigger the body to burn fat for fuel during exercise, instead of the body burning carbs (which is what usually happens). I'm losing weight plus I'm not sore anymore after a workout![]()
You aren't sore any more because you have purged your muscles of lactic acid. That is what causes muscle soreness. When you work out everyday it doesn't build up, so you don't get sore. OK, Pup's done trying to sound semi intelligent.![]()
Actually, you are correct. The soreness comes from breaking down the muscles. Lactic acid is the by product of that. If you work out regularly you break the muscles down much less and in turn produce much less lactic acid.
Consistency is the key to a less painful workout!....
Someone called??
Hey everyone, been distracted the past couple days. Busy at work, etc.
Kind of annoyed, took my glasses off, to clean the lenses, and they just broke in half right at the bridge. Didn't even snap though, I was finished cleaning them, started to lift them to my eyes, and half just separated in my hands. I have an old pair but the lens coating is all
Scratched up, they are awful to look through.![]()
I like the way they look and feel much better too, so I actually wear them more often...still wear my contacts almost every day though.You aren't sore any more because you have purged your muscles of lactic acid. That is what causes muscle soreness. When you work out everyday it doesn't build up, so you don't get sore. OK, Pup's done trying to sound semi intelligent.![]()
