...So I tried it on salvage mod, it was pretty simple, It should work on those other ROMs
I got it to work on the few ROMs that I flashed that didn't have it installed, sense or AOSP.
Let me retrace my steps...
edit: To get HULU to work a modified FLASH is needed. Stock wont work.
I found these on XDA, I forget where exactly, there where a few...This is how I got it to work for me.
Using titanium scroll to your
current flash player, wipe data then uninstall. Now go to your file manager (root explorer, astro etc..) install
modified flash then
HULU.apk.
It should work. From HULU app choose a vid, hit hour glass/white screen, wait, then it should start playing.
Only works with "APP" not from site. If you update FLASH, HULU wont work
...let us know how it goes!
