mrstealthusmc
not sure if anyone knows, but if you go into settings - about phone and tap on android version multiple times, you get a little surprise.... just thought i would share!!!!
Hey, do we still have the other easter egg that allows you to change the dropdown name? If so can someone give the instructions again?
Can I do that through the terminal emulator? If so how?
[not "bzzzzz" interestingly enough]Nothing for me.
You need to press it a lot, it took me around 30 or so taps to get it to work.
It only took 3 taps for me.
I was just messing around with it again, sometimes it only take a couple taps and other times it takes 20 or more for me to get it to pop up.
Edit: lol...I just had it take over 50 taps, then the next time it was 4, I wonder what triggers it exactly.
It's from all those years of breaking stuff when I was little, and then using my pointing finger to point at my sister in a "blaming" manner.....lol, or it could be all that digging for gold......
Can anyone else confirm that it does not work on .595
Im on .595 here also and it works every time as well.
