RichboyJhae
Could someone point me to the EVO gingerbread ROM with sense and working 4G? I saw it somewhere but lost the link. Thanks!
★ ☆ ★| WIP | VirusROM Kingdom REVOlution | A0.2 | 2.3.3 | SENSE 3.0 | ★ ☆ ★ - xda-developers
I have not yet flashed this but used other VirusROM(s) and have loved them. Will do this shortly.
here is a stable one that is great and has 4g also from virus but beyond alpha stage...
█VirusROM GengerSense ReV
I did not think this had 4g working?
UH OH Kingdom Beta 1 drops this evening! Loving this rom in alpha stage, buggy or not lol
What are the pros/cons IYO?
I was having issues with bad downloads of mirrors. Downloaded and booted up 3 times with 3 different mirrors and every one had the same issue.
I'm not brave enough to try to flash any of these yet. Too much risk IMO for losing all my data. Perhaps it's just the noob in me. I don't fully understand why one needs or has to downgrade their PRI as I've never done it. Anyone want to explain?
Thanks!
I was unsure at first but I realized that the 1.90 PRI was keeping my phone awake at all times with some of these roms from Virus. You can check in menu, settings, about phone, battery. Awake time and up time. If they are the same, I would recommend flashing the PRI 1.70.
Pretty easy, download from Virus's thread, boot to recovery, flash PRI, then reboot phone. Pretty simple
By the way, this has saved me battery life big time![]()
I tried B1 last night. Just seems really slow on my phone, and Maps doesn't work with GPS enabled, so meh, back to CM 7.0.3.1. I didn't like how it was hogging my phone's internal memory either. When it was syncing my google apps, I just had a slew of install errors due to insufficient storage. I saw that there is an option within Sense to move to SD card, but aren't apps a little less stable running from SD usually? I never really mess with it because I have tons of space on my phone's internal storage on CM7.
By the way, partitioning the sd card is a must if you are going to use this rom as a dailyInteresting! I was always wondering why people would change their PRIs. So do this mess with nands or anything? Do you ever flash back to the current PRI or is the 1.70 all that and a bag of chips?![]()
here is a stable one that is great but no 4g also from virus but beyond alpha stage...
are sure you want try this rom as your first? it is a bit more tricky then most roms out there. first, you need amon ra as your recovery or clockwork mod 2.6. second, you have to partition your sd card because the rom is quite large and there is not much internal memory. third, you have to downgrade your pri. that is a lot to do for your first. i would try some other roms to get some knowledge in then try it. but, if you are still wanting to, then we are here for you.
Thanks man I was searching for roms and I found that and it looked cool to me but I think you are right I dont want to brick my phone or somethimng like that also I wanted that rom because it uses the sense interface but you are right its to much for my first rom
Is there any rom you recomend me, I'll keep searching for roms.
Thanks again![]()
Hi again look I just saw this rom i know its in the initial stages but do you think I can flash this without having problems or its still to advanced for me
thanks again
