Root [GUIDE] Brick Recovery
If your phone is not activated, then you don't need to use the dialer code. That is only for restoring cellular service.
Otherwise, nothing is different.
I get stuck at a screen that says Factory Reset Status with a big red 2
could anyone help?
You didn't use board mode in the flash tool. You need to reflash, make sure you select board mode. (see the screenshot of the flash tool)
It's become clear that iRoot is useless for zv4, removed from guide. I've also removed StockWalk due to potential issues that have come up in the thread for it.
Got mine rooted, finally.
Couple of points, you may want to consider:
1. update host USB driver
2. get rid of USB hubs
3. get rid of VM, if you are using one
Thank you so much for the suggestion. The OP's process wasn't working for me multiple times when I was running Windows VM on Mac, but it finally worked when I switched an old Windows desktop. Figures...
Yeah, it's unlikely that trying to work through a vm will work for anything like this due there being an extra interface between the phone and the system.
im just waiting on somebody to push a full zv5 out rooted or not, deodexed or not, so i can start up development again. I don't want to waste time on zv4 when zv5 is here. i would have made the zip myself, but i don't have the resources nessecary.
Added the new zv5 ROM to the guide, credit to kwknott.
I've also removed zv4 from the guide completely and replaced CWM with TWRP.
Does anyone know how to edit the title of a thread?
Thanks for all your work on keeping this guide updated with the latest info!
You can edit the thread title via the web site.
Just wanted to post a quick update after having so much trouble with this a few weeks ago. Updated my laptop from Vista to 7 and... IT WORKS! Finally no errors with the LG Flash Tool, now hopefully I can get through Step 4 without any problems :)
