Dunno
Do you think I'm best just starting over or am I safe enough moving the backup I had from the PC to the SD Card & then maybe restoring a Nandroid from there?
Dunno
Ok had a go, it boots up OK with the SD card in so that's a start.
Downloaded Quick System Info & this is what I get:
SD Card storage Total 1.67GB Free 1.67GB
A2SD storage Total 0.98GB Free 857MB
Internal Storage Total 148MB Free 100MB
System Storage Total 250MB Free 22.68MB
Does that seem right?
I've only got 100MB Free & I've hardly any apps installed?
I tried redownloading, a newer and an older version, none worked. I think I'll just give up on this method and try using gparted some other way.Could be a dodgy iso. Try and redownload it. If after that it still happens, download the version before.
this guide is step by step process if you read the 1st page.. I've almost partitioned my SD card... I'm up to the section that says "Now you are ready to partition.
Either use Lecter's video guide:
Gparted Video Guide
Or my step by step in the root memory FAQ:
If I wanted to, is there a step by step process?"... What do I do now?
