I followed step by step and purple screen gone! But now the device is stuck in an endless fastboot, I've tried many things, even restarted my research and so didn't work ...
Updated symptoms:
- If I try one hard reset it hangs in the hard reset screen
- It gets stuck in the Fastboot screen:
[720] fastboot_init ()
[720] Error: ssd partition not found
[750] USB init ept @ 0x7ad0000
[770] udc_start ()
[940] - reset -
[940] - portchange -
[1840] fastboot: processing commands
For the love of God guys, what I can do?
- Downloaded the LG Laf multitool Recovery v1.2 and tried almost all functions (those that seemed useful) and continues in fastboot mode.
- The computer makes sound when the phone is connected and appears in the right corner the option to remove the device safely, but it is no memory detected, as if nothing had connected.
- I tried to make the Linux process again, but it does not detect the device, as well as Windows 10 ...
una pregunta el aboot se saca dentro de la carpeta almacenamiento interno del celular? por que cuando lo conecto al pc busco y en la carpeta almacenamiento interno del celular me aparece aboot archivo bin y el otro que se llama abootorg archivo bin...
Hi I speak spanish. I am using the google translator, I hope you understand me.
I have a LG L70 and the symptoms that are very similar to those of this publication, but there is an exception! When I connect my phone to pc (windows 7) I do not detect any partition, but detects as qhsusb_bulk. When I use ubuntu does not detect anything. The funny thing is that a few days ago the windows 7 detected it as relink hs-usb qdloader 9008. I hope you can help me.
hi, not new to the thread but first post, so I have the D321 and was able to root using the D32110d firmware.. got all the way to pac man rom then tried to go into recovery mode thru twrp and that's when everything went downhill. BRICKED, I was trying to use this guide, but I'm missing the 2 folders (image and verinfo) when I plug my phone up on windows and when i hook it up on Ubuntu it just gives me a thousand errors and flashes, even tho it's just a black screen. Any idea where I could get these 2 files??
[FIX] Unbrick LG stuck in Qualcomm HS-USB QDLoader 9008 mode
http://forum.xda-developers.com/lg-g2/general/fix-unbrick-lg-g2-stuck-qualcomm-hs-usb-t2933830
Stock firmware in for LG L70 D325 .tot :
http://4pda.ru/pages/go/?u=https://yadi.sk/d/nswOFPREnA4rK
http://4pda.ru/pages/go/?u=https://cloud.mail.ru/public/4NmCg3YR3fUt/LGD325V10gCIS.7z
Thank you:
dvj_frost
yes, I used LitrosNub videos, and I'm sure that my problem was that they were for Metro PCS and I was cricket.. It actually bricked installing the Gapps.. After I installed PacRom and Gapps onto my sd card, I went in recovery to wipe cache,etc. Like the video says and it took the PacRom, loadeded it and everything but my phone was saying not enough storage to install Gapps and I can't remember what happened exactly after that but it is bricked now. I have VM and Ubuntu and when I hook my phone up it just freaks out error on sdb34 over and over....
Update: plus, someone snapped an image of their 2 files IMAGE and VERINFO, so i know what should be in them but I cant write code or anything to just copy those files and make the folders from scratch. but I'm sure that is why it is freaking when plugged up in Ubuntu
Can I use this tot firmware on LG L70 D325F?
Thanks in Advance!
exactly, the phone is just a black screen yet vibrates when trying to power it up or off i guesss. i'm trying to follow this guide through VMWares and Ubuntu..but i'm missing the IMAGE and VERINFO folders and have searched everywhere for them. please help
Is your device recognized as qhsusb_bulk in Windows device manager? This is important, since you are using a Virtual Machine with Linux, not Linux alone.
Hi all, I just want to said Thank you to Partarger.info member of xda forum for your guide for LG G2 that I used to fix my phone after that I followed this guide to put in my phone CWM recovery and no one was able to help me or tell me something about this problem.
The problem to this situation was you wrote over the aboot which is needed for booting the phone.
Symptoms:
Requirements:
- No download mode
- No Recovery Mode
- No fastboot
- Just Blacks creen
- When you connect the phone to pc you can see two folders: one is "Image" and the other one "verinfo"
- LG detected as qhsusb_bulk in device manager
Step by step
- A little Knowledge of linux
- You will need to use Linux, you can use Ubuntu or another that you want. You can use a virtual machine, live cd or a bootable usb stick.
- Download stock aboot of the phone from here.
- Boot into Linux and plug your L70 to the computer. Note: if you have linux in a virtual machine you must have installed in windows qshusb_dload drivers
- Put the downloaded file decompressed in the desktop
- Open terminal in Linux then type:
It should appear something like this:Code:ls /dev/sd*
Code:/dev/sda /dev/sda1 /dev/sda2 /dev/sda5 /dev/sdb1 /dev/sdb2 /dev/sdb3 /dev/sdb4 /dev/sdb5 .......... /dev/sdb34
- In this case my device is detected under sdb. you may have it under sdc. look for the biggest number, in my case /dev/sdb34 so it is sdb.
- In terminal type:
you will get something like this:Code:sudo gdisk -l /dev/sdb
Code:Number Start (sector) End (sector) Size Code Name 1 4194kB 71.3MB 67.1MiB 0700 modem 2 71.3MB 72.4MB 1049kiB FFFF sbl1 3 72.4MB 72.9MB 524kiB FFFF rpm 4 72.9MB 73.4MB 524kiB FFFF tz 5 73.4MB 73.9MB 524kiB FFFF sdi 6 73.9MB 76.0MB 2097kiB FFFF aboot 7 76.0MB 76.5MB 524kiB FFFF rpmb 8 76.5MB 77.1MB 524kiB FFFF tzb 9 77.1MB 79.2MB 2097kiB FFFF abootb 10 79.2MB 81.3MB 2097kiB 0700 pad 11 81.3MB 84.4MB 3146kiB FFFF modemst1 12 84.4MB 87.6MB 3146kiB FFFF modemst2 13 87.6MB 104MB 16.8MiB FFFF misc 14 105MB 138MB 33.6MiB 0700 persist 15 138MB 161MB 23.1MiB FFFF laf 16 164MB 187MB 23.1MiB FFFF boot 17 187MB 210MB 23.1MiB FFFF recovery 18 210MB 213MB 3146kiB FFFF fsg 19 214MB 214MB 524kiB FFFF fsc 20 214MB 215MB 524kiB FFFF ssd 21 218MB 219MB 524kiB FFFF DDR 22 222MB 223MB 524kiB FFFF encrypt 23 223MB 223MB 524kiB FFFF rct 24 226MB 235MB 8389kiB 0700 drm 25 235MB 243MB 8389kiB 0700 sns 26 243MB 264MB 21.0MiB FFFF factory 27 264MB 298MB 33.6MiB FFFF fota 28 298MB 299MB 1049kiB FFFF sbl1b 29 299MB 332MB 33.6MiB 0700 mpt 30 332MB 333MB 524kiB FFFF eksst 31 336MB 1961MB 1625MiB 0700 system 32 1961MB 2275MB 315MiB 0700 cache 33 2275MB 3888MB 1612MiB 0700 userdata 34 3888MB 3909MB 21.0MiB 0700 grow
6. We are only interested where is located aboot partition, in my case is located in sdb6. Be carefull because in your case it may be located in another partition. not be confused with boot partition or abootb.
we will use dd commands to push aboot.img inside the right partition.
7. in terminal type:then type your passwordCode:sudo -i
now you must be under root access.
8. type the following dd command:Note: alexdream is the name of the user in linux, you have to replace for you own user. Replace this path by the appropriate path to your fileCode:dd if=/home/alexdream/Desktop/aboot.img of=/dev/sdb6
Once you finish just reboot your phone, if everything was good your l70 now can boot normally and you can go to the download mode too.
You can follow this guide to replace recovery is you want, just remember not replace stock recovery to the recovery partition.
This guide is for LG L70 MS323, other variant can work but you have to search stock aboot file.
DISCLAIMER: I am not responsible for anything that may happen doing this. Make sure to make it right!
if you fixed your phone can collaborate to pay me a beer
Paypal
no, the device manager says android bootloader interface with the (!) by it.. that's all
plzz help my lg l70 is stuck on dpi err fatal I tried all key combination to get in to download mode but was unsuccesful Also tried lg laf multitool but device is not connected as my phone wont boot in fast boot or download mode also trying linux aboot method but ther also on terminal is hsowing access denied plzz help me I am using linux alone but I dont have idea about my LG phone which rom it has
And it giving permission denied
And I have to type the command
/dev/sd*
and not
ls/dev/sd*
it showing no such directory
but I have sdc till 35 in dev folder
plz help me what to do
Infact the emmc is clean as I've erased it in BoardDiag 3.99 and trying to read/write but I still fails, how can I fix this issue?
plzz explain d key combo of lg l70 as I m cofusd.. vol up + power to plug USB & old vol upHi @Swathi Jangam. Posting the same question four times would not fix your problem
The problem is probably caused by flashing wrong aboot file. Here's the dump that may rescue your phone: [Dump] [All Variants] Aboot, files and how to flash.
Are you sure you did the download mode key combination correctly? Was your USB cable plugged in while doing the key combo? Check this video: LG L70 Tips and Tricks [Video Guides]
seriously... cofusd
sri. sum kes not wrking
