No problem. I found this link, not sure if it will help you:
http://inphic.com/downloads/tools-drivers/download/32-spot-i7-root-patch
Also per the site:
With this patch you will gain root access to your device. To apply this patch, download this file to a USB external storage, and use UPDATE&BACKUP app in My Apps. If you need assistance, contact support@inphic.com
Hopefully this helps.
Hi thanks so much elaine [emoji3]
