Cheers!
I Have Obtained Root,Not Just Any Root...Permanent Root For Zv4!,Long Story Short,I was In A Rock In A Hard Place,It Was Either Create A Coustom Rom For Both Devices,Orrrrr...Create A Modified System.img That was Prerooted(I Choose Modifed System.img),But I Quickly Realized That I Could Try To Push Su Manually The very hard way,I Decided To Try The Zv3s Verson Of Root But A Little Bit Diffrent...And It Succeded,Also If You Guys Need Help Learning How To Use Adb I Have A Few Videos,Also I Need You Guys To Test Something for me! (Try Accessing adb And "Adb Reboot Bootloader" Without the "quotes"! So The way To Root Zv4 is Going to require A Little knowledge..I Need Someone to test How to Boot into Bootloader! Also How Did I Root It I Flashed Two Diffrent images From Both Of Zv3,And Zv4 To Accomplish This But You May Be able To Use My Zv4.Img To Get Root,All I Need Now are Some Testers Trying to Get Into fastboot!
