Root Help Rooting LG Stylo 2
Well Guys There Is A Way To Root The Lg Stylo2 And You Guys Should Check It Out Can You Guys Rate And Add Nice Comments To My Friends App Its Called Root Android Without Pc And I'll Post The Link Thanks & It Really Works :D
I wish someone would find a way to root it. I hate not being able to have my LG Stylo 2 LGLS775 not rooted :( I love this phone, its great. But would love to have it rooted as well :)
Well Guys There Is A Way To Root The Lg Stylo2 And You Guys Should Check It Out Can You Guys Rate And Add Nice Comments To My Friends App And I'll Post The Link Thanks & It Really Works :D
Im still working on root i have been sick. My wife's phone is on zv3 since she got it i have the zv3 kdz file thats posted soon as i can get the lg flash tool or lgup to work i get back to work. I have put in an request to Supper r for help but no responce yet so others that did get the root seemed to not respond to me for help we are on our own again just keep pushing the request with kingroot
I found more info on the lg flasher and lg up i try it out and let u people know. Can any body here tried lgup i cant get it to find the dll it needs i installed it like it said to but no go same with the lg flasher cant get it to find phone
What about zv8 its for Boost Mobile
For now havent gave up im trying to get some devs to help for root just keep doing the king root to push up the request
Read over everything new since been gone. Checked, got the nougat update also. Guess I'll factory reset, logcat it & try to intercept this entire update. May be better luck on Nougat!
I could not get LGUP to load either (couldn't load model). I found this link https://www.androidsage.com/2016/04/12/update-t-mobile-lg-v10-android-6-0-marshmallow-h90120e-lgup/ Scroll down to the section that reads "How to fix the LGUP can’t load the model [C:\Program Files (x86)\LG Electronics\LGUP\model\com] ?" . Specifically I just downloaded the common.zip, extracted and placed the common folder under the model folder. LGUP came up with my phone listed. If this is the same problem you were having maybe this will help.
What did u flash and did it work?
Haven't flashed anything yet. I just wanted to see if I could help get LGUP running and recognizing this phone. I am hesitant to flash anything right now. I am still on zv3 with temp root and would hate to screw up it!
Ok i try it im on zv4 have the kdz for zv3 i try to figure it out
