Can i remove the stock camera and just use another camera app because my camera jsut stopped working otu of nowhere and i cant get it to work!
Im not rooted btw.
go to your phone browser, or just download 4shared, the app (or internet) and type in "gingerbreak" and download v.1.2 and see what happens. if it still says a error than go to settings->application->and make sure the first option is checked "Uknown sources"
Yeup. did that. and the box was checked.
Still said unsuccessful. -___-
wonder if anything would go wrong if you deleted the rich pad app thing.
did you use Root Explorer?Tried to uninstall uno and it says " failed to locate apk file " any idea what that means?
thats the app you need to do it with. Everyone has had problems trying to do it with TiBu.? what is that
)if your stock or on a modified stock ROM ther is none, its maxed out at 600Mhz. Lots of ppl like tibu for backing apps and data up etc. Personally I dont like nor use tibu thook thanks a bunch, I'm already rooted and have TiBu. Do I still need Titanium Backup? and what the best app for turning up the juice a little
not legitimately, so on that note I will say google is your friend if funds are an issueIs there a free version of root explorer?
if you rooted with gingerbreak busybox is already installedOK got root explorer now what? AND do I need busybox what does it do?
Now you navigate to the system/app or cust/metropcs/us/app directories and delete what you dont want. Just make sure to press the R/W button on the top right of the app.
If you want all of the metro bloatware gone you can just delete the whole app dir in cust/metropcs/us.
speaking of, did you ever upload those files that are needed? I may update PM with em if ya did+1
what he said, just dont delete the whole metro folder...![]()
speaking of, did you ever upload those files that are needed? I may update PM with em if ya did![]()
also i have 2 versions one with app folder deleted and the other one has everything in it.yep, will post link here, have to re upload em.also i have 2 versions one with app folder deleted and the other one has everything in it.
cust.rar , original folder with everything.
cust app folder remove.rar , folder with app folder remove.
