shantytownbrown
Partner, I don't know what to tell you.
Possibly a bad dl to begin with? maybe dl it again?
Which recovery are you using? Amon ra 2.3, i hope?
Did you wipe really well before you flashed the rom? perhaps you could try that or even a different rom, and check the phone out first thing before you restore anything?
That being said, do you have titanium backup and tb pro to back up your apps so you can restore them on new roms?
flashing a rom over itself, after only wiping cache and dalvik cache is usually a good way to straighten things out without messing with your setup.
Maybe someone else will come by with a suggestion to help.
yes amon ra, and yes i wiped then did superwipe before i flashed...
could it be my kernel?
i chose tiamat 3.3.7-sbc as it was suggested by someone else on the forum, maybe its the sbc part, i can get the one without, but i dont know enough about the difference to know if that will work.
i guess i could always try a new DL as you suggest..
i'm gonna keep reading and searching, i know the answer is out there somewhere!
