r_pie
Im new to Android Development, and I need to create an app that opens another app like so:
I open App 'X', which then goes and opens App 'Y' and App 'X' closes itself in the background. Any assistance as to how I would make this? I need very specific guidance, because Im very stupid lol.
Pre-written code examples would be greatly appreciated, but a step by step guide on doing this would be insanely helpful.
edit: just tell me how to open the app from another app pls i beg
Pre-written code would be greatly appreciated, but a step by step guide on doing this would be insanely helpful.
step by step guide? that is a very tall task you are asking. coding android is not easy. there are a lot codes that needs to be performed for what you are asking. i am no dev, but i have rooted phones and understand a bit of android.
what you need is to find an android developer studio. you can then hire a dev to help you out. they are not cheap though:
or you can take the time and learn yourself. here are some links to get you started:
Thank you so much for that help, its given me some good places to start lol. Unfortunately hiring a dev was out of my (non-existent) budget lol
Is there a page anywhere that explains opening another app from inside an app?
