waltzngmatlda
ive turned off vibrate when phone rings but how do i do this for text messaging?
Try downloading Asto that makes it easy to see whats on your SD cardDoes anyone know how to add portable versions of movies? I linked up to the computer thru the USB and saved them to the internal memory, but I can't find them anywhere on the device. They don't show up in the gallery either.
For text notifications? Or typing?
=p
for text notifications. i got the typing bit.
i don't believe this is correct. Holding down the home button shows you the last 6 programs you used, not which programs are open.
Do you need to uninstall the previous version first?
If so, how?
No, you will need to convert the music to mp3. M4p is a drm protected file.
On the default "Work" scene home screen there is a widget that shows an upcoming event from my calendar. I wanted to add this to another scene, but I don't see a widget that does this. Anyone know how to get this widget on another scene?
Note, he said "M4P", not "MP4"Not necessarily true. I imported all of my music into iTunes in the mp4 format and none of those are DRM, only the ones I bought from iTunes.
Menu > Settings > Privacy > Use My LocationHey guys how come when I voice search it doesn't take in account where I am in results? My brother in laws droid does it automatically. I made sure location and gps was on. Any help much appreciated. I love this thing!
M4P, not MP4. M4P is the protected format.
File Extension .M4P Details
It will only play on the authorized device.
I found out that you can just change the extension on the file and it will work fine in any program other than itunes. I don't have many protected songs, so that's a lot easier than burning CDs.M4P, not MP4. M4P is the protected format.
How do you find draft text messages? Is there an easy way?
This is now working, not sure why it wasn't before. I was playing around, received a new text message, turned it to landscape and wa-la, the horizontal keyboard appeared. I didn't make any changes. Thanks for the suggestions, all is well now.
