MoPhoMan
Does anyone know how to movie pictures and video taken with the phone to the SD card? I try looking under settings and didn't see anything.
you can connect to a PC or download a file manager app from the market
What file manager app do u recommend? I tried astro and could not figure out how to move the picture over.you can connect to a PC or download a file manager app from the market
i am using astro too...highlight the photo you want to move and then select move and navigate to the folder you want to place it
ok...here are my dumb questions (i'm new to smartphones so please bear with me), is there an app for the radio that you can listen to without having a headset connected? (that would play through the speaker phone?). I downloaded handcet for texting and like it alot. However, is there a way to get the phone to quit telling me that I have messages on the preinstalled messagining wiget as well as in the top left corner of the phone - neither will go away unless i open the widget that was preinstalled on the phone. Also, does anyone have the song tomorrow for the musical annie that would be willing to make me a loud ringtone with it? I have always used that for my mothers ringtone yet I lost the song when my computer crashed a while back and i can't find it anywhere on the apps available. (i'm sure its not a highly sought after tone! but my mom took me to see that when I was just a kid and i got to meet the girl playing annie) Thanks to anyone who helps me with my dumb questions....i'm sure i will have more but i have had this phone since wed and still really have no clue whatsoever as to what i am doing on it. its such a learning curve and a challenge but i do love the phone!!
You might want to format the SD card via the phone. It'll erase everything on the phone, but everything should be recognizable once you transfer it back to the SD card.Hi, I followed the instructions in the user guide to transfer files to the SD card. In my case it's 15 gb of mp3 using a 16gb Class 6 sd card.
After transferring (which went flawlessly from the PC's perspective) I opened up the Music App and only the original 9 songs which came installed on the phone were there- where are the 3700 that I transferred?
Furthermore, the SD card shows up as empty on AstroManager, but shows up on my PC with all the files installed.
How do I access my SD card to get the files into the Music App?
I appreciate anyone's help to figure out what I'm doing wrong.....
I have been trying to figure this out for two days! Thank you so much!!! It worked!The only way I could figure out to remove my synced Facebook friends from my phone (particularly from the phone dialer) was to remove the Facebook account, then add it again. However, after you enter your username and password, be sure to cancel the sync before it completes. Then you can go into the Facebook setting and uncheck sync contacts, and they won't show up in your dialer.
There must be an easier way to do this, but this finally worked for me.
Do you have auto dim activated on screen setingsWas watching a youtube video last night in the dark and the home keys stayed on. They were so bright it was hard to watch the video. Any ideas how to dim or shut them off?
Well, I tried "auto brightness", works for the screen but it doesn't seem to affect the brightness of the home keys. Where is the "auto dim" you are referring to?Do you have auto dim activated on screen setings
Update: I re-booted and they were all there. Problem solved!! This music player still sucks, it's totally unresponsive and incredibly slow. Anybody having any luck with other music players?
Can you mention the types of animations are turned off with "Show some" and which are turned off with "Turn off animations". The only animation that comes to mind is the sense animation when you pinch from the home.
New to Android and want to thank everyone for there help. Could someone tell me if there is a way to assign a MP3 for individual contacts for notifications? I can set stock tones, but haven't been able to figure out how to use my own MP3's?
I asked this question separately, but I figured I'd post here to see if I'd get a response.
Is there anyway to use double touch under the Phone list to dial a contact? It's so touch sensitive that even scrolling through the list, I accidentally called an old Facebook contact.
I want to know if there is a way to make my phone continue to notify (ring)
when I get a text message if i don't look at the message.
I am a physician and on call at night the one sound does not always wake me.
