I want to write some scripts to run on my phone so I can test my settings while I'm sleeping. I use my phone for an alarm, witch was nasty the other morning. It went off while my phone was locked to 64MHz. Try it! Not a healthy noise. I couldn't unlock the phone, so I ran out to the living room and eventualy had to pull the battery. Well, I had the idea if I could run a script, I could set it to end the test, change the processor speed, what ever. I've written some scripts before, but I don't know where to look to change the processor speed, or if I could end stability test by command. google that in a moment
I know you guys know your way around theese kernels, I thought I would ask. May even be of some use![]()
I think running stability test at a frequency for more than 30 minutes is really not necessary. If it hasn't crashed or detected errors in 30 minutes, it probably won't at longer times.
HAVS hasn't been mentioned in a while, is there still a possibility of it being included?
No, I haven't really had much of a chance lately to look into it. What kind of stuff do you see that is interesting?
With the fixes, have you tried leaving WIFI ON and set to disconnect when the phone goes to sleep? And does the phone wake up ok again after about half an hour of sleep?
And also when WIFI is set to Never sleep. Does it get the sleep of death and needing a batter pull? Used to take > 30 min of sleep before that happened.
Thanks.
would you also be able to update mock kernel?
Yes. Will be looking into that as well.
sorry for the stupid question but id like to flash this to my MT running cm7 3/4 build and i was wondering how can i properly flash it? last time i tried it wouldnt boot past the boot logo.
Mantera, I used to use this kernel.
What are the current differences between this and Whyzors current kernel, and what results would you expect when swapping with this one.
I added a test 1.7.20.zip file to the OP. This reverts the commit that tries to prevent 2 sensors from grabbing wakelocks. It looks like it's possible that when only one sensor is active, it may not be able to grab a wakelock.
Let me know if that helps.
Yes! the screen comes back on when I pull it away from my ugly mug!
You're the man!
