4ndroidtech
I have the LG Optimus S with the OV's ClockworkMod Recovery and the BACKside ROM flashed on it. This was pretty simple, but my question is: Is there any way to get the LG Optimus S working on Virgin Mobile? And if so, how?
No.Not to mention that IF you successfully do it, you will most likely experience service issues such as 3G not working, and MMS not working. These are also problems some Cricket customers experience when they flash their non-Cricket devices to be used with Cricket services.
And if i do recall reading a thread over at howardforums.com about someone succesfully flashing an HTC phone over to Virgin Mobile(before there were any android phones on their network about 2 years ago) and were experiencing such data and mms issues.
No.
They only experience 3g and mms issues if the person doing it did a half-a$$ed job and/or didn't know what they were doing. VM is harder because they have screwy mms, but other than that, they are all similar.
I know of several Evos and Epics running fully functional installs of CM7 and ICS. I've had first hand experience with the Evo on VM.
Thanks for all the info! I actually have the MT on Virgin Mobile. I also have an old OV. I had just been messing around with this Optimus S(bad esn) and was wondering if there would be an easy way to switch the service to Virgin. But now I see that it would be a royal hassle![]()
I am interested in trying this as I have some Optimus S phones laying around. I wonder if doing this would cause MMS to fail
Shouldn't, they both use the same mms settings. Since they are the same network.
If someone used the unbrick guide, they could easily reprogram the phone for VM
Yea, but then they would also need a virgin mobile esn.
Cloning esn is illegal. DON'T DO IT!
If VM accepts optimus s on their network like Leslie said then you won't have to...
Go to Virgin's website, log into your account and click on swap phones. You will see the Optimus S.as one of the listed phones. I don't know if you activate it on a new account, but you definitely can swap to it on an existing account.
