liquid0624
Couldn't have said it better myself UB gj
Couldn't have said it better myself UB gj![]()
its not letting me install it. im on clockworkmod recovery and it keeps saying it's bad! what do i do?![]()
Check out these new kernels by slayher: Froyo Kernels by slayher - CyanogenMod Forum.
Working great for me.
I can't thank you enough for finding this. I have been in disbelief that I my Droid has a "top speed", that I can't score but only so high in Quadrant and such, and how I can't seem to get 1.2GHz stable on my Droid since moving to Froyo with most ROMs. My highest bench was with LFY1.0 and jdlfg's 1.1GHz kernel and that was 1569. All I ever dreamed of was just making it to 1600 someday, as my Droid kept inching closer and closer. My wait, is officially over. And while the picture below was my highest bench, it was pretty consistently in 1600s.
This was running at 1.1GHz. I almost had 1.2 stable, but as soon as I went for a bench, my Droid threatened to self-destruct. lol My day is officially made. Thanks again! And thank you slayher, whereever you are!
after reinstalling i am loving this rom, running a lv 1.1 chevy kernel. only thing i don't like is when you make a call the phone gives off a short vibrate at the beginning and end of the call. how can i deactivate this?
Can I remove seeded apps like twitter in ClockworkMod Recovery?
I just installed this patch without issue. Are you running the 1.4 ROM?
If so, just place this file on your sd card and select "install zip from sd card" once you boot into recovery. Select the 1.41 file and then confirm. Should install quick and easy.
UBR, did you wipe before installing the patch? Just curious to know if I can apply the patch without wiping..
how come everytime i download the 1.4 ROM, i cant open and view the files on my computer (it keeps saying invalid file) and when i try to install it on my phone with clockwork recovery, it keeps sayin the installation was aborted cuz the file was bad....my friend has liquid frozen yogurt and i want it really bad!!![]()
It's possible the file got corrupted. Did you try downloading the v1.4 ROM file again?
i even tried downloading 1.3 but that says the same thing and does the same thing
