DroID AddIcT 14
Can you try DLing it on your Droid -- I always use DolphinHD for this. Then you can mount your SD and should be able to view it on the computer.
ill try
I have noticed a couple bugs. One of them is when you use the keyboard slide out and u use the alt key some times it sticks on and sometimes it doesn't. Loaded this clean wiped 3 times. Also when you place a call it has Chevy bow tie and SS on the screen, not a big deal but the keyboard thing makes it hard lol Also no Matter what p3 lv kernel i use i only get 600 its like setcpu doesn't like them any ideas?
Let me know what you think.
thanks
Larry
just tried and my phone said it was unsuccessful. wtf is going on????
Turn off USB debugging.
My wife's phone is the same wayNo matter what ROM...(even when it was stock) the phone MUST have USB debugging turned off to mount to the computer.
I don't know why...but give it a shot.
no good. i tried downloading the ROM from my phone and the exact words that were given to me were, "Cannot download. The content is not supported on this phone." Maybe it's because im trying to put it on a Moto Droid? but then again, my friend has the same phone as me and he has the ROM so idk...
you using the stock browser? Seriously, try dolphinhd.
omg its downloading on my phone now from dolphin hd!!! Wow lol
You using the stock browser? Seriously, try DolphinHD.
Hey Now...Don't dis the stock brower...I love that browser!![]()
YAAAYYY!!!!!!! its done![]()
Sorry, it wasn't my intent to dis the stock browser -- it's just finicky about downloading files. I use Dolphin for all my downloads -- not only is it not finicky, it also gives me a popup and lets me confirm that I do indeed want to DL that file.
Have you tried re-flashing clockword? Try flashing spf recovery through ROM manager and then flashing clockwork again. You might have to try an older version of clockwork (found under all clockworkmod recoveries at the bottom of ROMmanager). Hope that helps.how come everytime i download the 1.4 ROM, i cant open and view the files on my computer (it keeps saying invalid file) and when i try to install it on my phone with clockwork recovery, it keeps sayin the installation was aborted cuz the file was bad....my friend has liquid frozen yogurt and i want it really bad!!![]()
Applied the update over 1.4 and now every time I try to use the android keyboard it force closes.
I've tried everything: fixing permissions, wiping cache, reinstalling, removing my smoked glass theme, and even wiping everything and installing the update over a fresh install of the rom nothing works.
I am having the same problem. Updated with the patch and now each time I try to use the on-screen keyboard after a couple of letters it gives me the option to force close or report it.
I didn't see the problem with the patch...but I'm running a version 1.5 alpha buildwhich never had the Droid2 keyboard.
Go to settings > language and keyboard > uncheck the box for android keyboard, and then recheck the box again...that should fix your problem (per liquid).
Checking/un-checking the box didnt help the first time I tried it, but after a few times it magically started to work just fine.
installed the patch for the keyboard now it just force closes after two letters
any ideas?
any ideas?
any ideas?
