SigmunDroid
Member
is there a Google voice made for this ROM?
The link to the Sexy mobile video appears to be broken, think you can re-post?![]()
You using the stock browser? Seriously, try DolphinHD.
There's a Google Voice in the Market. If you're looking for an inverted (black) Google Voice, see here: Themed Google Voice? - Droid Forum - Verizon Droid & the Motorola Droid Forum
. I personally liked the Droid Does into the Droid X, but that's not really relevant. It beats the stock animation. Like usual, it didn't take but maybe a minute to load. Then I was surprised when my password was incorrect. Yeah. That was the Droid 2 keyboard, and issue already fixed by Liquid w/ the LFY1.41 patch. Market synced within 30 minutes (probably less, but I sat the phone down for about a half hour before I remembered I usually time that...sue me).Here's a thought...
The black bar mod you are running basically isn't the same as the other themes in terms of function. Launcher Pro is not a system app in the stock build of this ROM but when you apply a theme, LP is moved to the system directory. What this does it that LP gets memory allocated at a higher priority.
Try this...make a nandroid backup, run the Smoked theme and see if LP is faster at redrawing those icons. This ROM is BY FAR the fastest in terms of redraws that I have ever used. Flipping the phone into landscape is almost seemless. LP in the system dir is not the only cause for this...but I believe it helps.
Also, my wifi doesn't work. I've tried it on SS v4.6 and it doesn't work. I am using the stock kernel that came on this ROM...
whenever I try to connect it says: Obtaining IP address, then it says: Remembered, Secured with WEP.
It just won't connect. I've typed in the password and everything...wtf
Guys, if this has been answered somewhere else, I apologize in advance, but I didn't see an answer in the thread...I'm having the same issues with WiFi. I turn it on and though I've typed in my WPA key correctly, it starts by saying "Scanning.....Authenticating.....Remembered.....Scanning.....Authenticating.....Disconnected."
Then it just says in the WiFi networks spot: "Disabled, secured with WPA/WPA2 PSK"
So far, this is the only major thing I've found with the ROM that isn't working well. For the record, I'm running Stock (no theme) LFY 1.41 with So far, this is the only major thing I've found with the ROM that isn't working well. For the record, I'm running Stock (no theme) LFY 1.41 with PS3 ulv 1.0. Any help, of course, is greatly appreciated.
This is going to sound stupid, and I have been running rom's for 8 months now but... If I make a backup will the theme stay? And can I install a theme over another theme?
running 1.41 too with the old keyboard and i also force close after 2-3 letters, what do i do? i wiped data and cache when i flashed this rom.
seems to be a common issue? please help us, i love this rom but i would like to be able to use the android keyboard as well as the physical one.
I removed Facebook with a Script, it wont download from the market. How do i get it back?
