GirLuvsDroid
Android Expert
So I must flash the newly created combined "theme" as an update.zip
basically and flash via Clockwork? I took a look inside the Google Quick Search apk, renamed to zip and looked and found all of the images
for the Tangerine widget.
For some reason on my Droid 1 the lower case g and the word google is
low res and doesn't look as sharp as the black and bold theme.
No worries.
I think I'll back stuff up, and go for it.
One really important thing to remember is that you NEVER unzip the apk -- you open the archive in 7zip and drag the folders with the images to your desktop, change the images you want to change, then drag the folder back to the 7zip archive -- never unzipping.
