My panda is starving!!!!
Can't get my phone recognized by adb. Figured I'd start with the SD backup via terminal since I've never done that before, Installed Ubuntu and mini SDK, had to install the 32 bit lib to get adb to work even tho I installed 32 bit Ubuntu.
USB debugging on and set to charge only, ./adb-linux devices returns no connection. Different usb ports, different cables including the one that came with the phone, restarted comp and phone several times, nothing works. Ran chmod on abd and fastboot like the mini guide says.
Pretty green on Linux (I used to kinda know something called Unix
) I have the full SDK on Windows, didn't want to bother for now in Ubuntu. All advice I can find elsewhere is for developers and the full SDK. Do I need to edit the android rules files, and if so where are they? Am I editing 50 or 70 or some other number, do I need to install some kind of Java?
Figure I'm probably missing something simple, but I'm pretty stuck and don't want to get in too deep since the mini SDK guide, this guide, and the SD backup guide lead me to believe it should not be this complicated. Any ideas what I'm missing?
Toshiba Satellite x64 i3 2.08 G 4 megs, dual boot Windows and Ubuntu. ARRRRRRGGGHHH
Gonna sleep on it.
