Root LTEVO ROOTING FOR DUMMIES {The Complete Guide}
So to flash Viper I DON'T install from recovery, correct? Also, how do I make a Nandroid backup? Never done it before. Do I need special files to create that?
no you flash viper thru recovery you just do not need to wipe. when you flash viper there is a program that gets launched on your phone. it will have its own menus and options and you will need to wipe from there. the program is called aroma installer.
as far as nandroid backups. it is in the second post. my suggestion is to take the time to read all of the second post when you get a chance. there is some really good info there.
Will do! Thanks for the info! Downloading Viper now! I LOVE that they took over Sprint's OTA update notifications and INFORM whenever an update for Viper is available! Plus it just looks SIIICKKKKKKK!!! Can't wait for my LTE to "Get Bit" haha
You'll dig it.
Please ask questions about it in the Viper4G thread if you have any.
Much of what you want to ask is already answered there. ;) :)
You'll dig it.
I'm sure I will. Especially since I'm sure it will be Bad A$$ since YOU were on the test team, and seeing how helpful you've been to a newb like me to rooting & haven't got fed up with me bombarding with random questions! haha Thanks for EVERYTHING EarlyMon and Ocn!
Even after installing Viper I'm still not able to use WiFi Tether. My computer isn't even picking up any sort of signal from it. Before I had installed Viper my computer was picking up the ad-hoc signal from WiFi Tether version 3.2 beta 2 I had downloaded, but as mentioned before, my phone just shut it down. I'm not sure if it possibly is happening because I had trouble getting twrp flashed originally. Other than that, I have no clue why WiFi Tethering isn't working for me, because my buddy is using the same version on his phone, and my computer picks the signal up perfectly! Are there any special settings I have to choose on WiFi Tethering that could be causing this? On my original Evo I had WiFi Tethering and I had it set up on softap (master) i think, showing bars like a normal wifi signal, instead of the ad-hoc w/3 computers. My Xbox wouldn't recognize it as an ad-hoc. Any suggestions?
Woohoo!! S-OFF finally. That took forever! Prep work was the most time consuming of course (sdcard backups, RUU/DirtyRacun downloads, etc). Just glad to finally see the racun escaped. Not quite as easy as Regaw method, or even the OG Evo days, but not too bad now that it's done.
Now on to flash something. TWRP i guess is first and foremost
NICE!!!!!!!!!!
congrats:D
Hello, I've read through all of these posts and I've already unlocked my phone, and ready to flash Viper onto it. My question is, as my phone is at 5.07.651.6, is it currently possible for me to get S-off? I've done a lot of research, it's just that there is so much information out there, that it's hard to know what is still applicable, and I really don't want to end up bricking my phone.
My model number is PC36100,
Hardware version 0004,
Android 2.3.5,
Kernel 2.6.35.10-g8b16b68,
build number, 5.07.651.6 CL558861
HBOOT-2.18.0001
Radio 2.15.00.01.15
If I can't get s-off, is there any major problems I'll face from that? I understand I will not be able to flash kernel or radio updates, but is that something I really need to be concerned with? I think that I will be happy being Unlocked and S-on, but I like to get as much as possible out of my products.
Thanks for reading
Android 2.3.5,
HBOOT-2.18.0001
Radio 2.15.00.01.15
Thanks for reading
welcome to the forums!!!!!!!!!!!
ok hold on here, you are in the htc evo 4g lte root forum. you need to go here to this forum:EVO 4G - All Things Root - Android Forums do not use this guide to get s-off as dirty racun is device specific to the evo 4g lte.
use this guide:
http://androidforums.com/evo-4g-all...-rooting-gingerbread-2-3-5-dummies-guide.html
and yes you can get s-off on your htc evo 4g with no problems.
edit: ALSO DO NOT FLASH VIPER AS THAT IS A EVO 4G LTE ROM. this could potentially brick your phone. roms are also device specific.....so be careful on what you flash.
Wow, I feel pretty stupid, because I even looked up pictures of the LTE before I started researching to see if that's the phone I had (I didn't buy the phone, someone gave it to me as a gift [hand-me-down]). Luckily I got lazy yesterday and decided to postpone flashing a recovery/ROM until now, so there was no problems. Well, this has been embarrassing, but thank you sincerely for your help.
ok good i was worried that you did not see my post in time......whew!!!! disaster averted.....lol
so yes use the guide i posted and you should have s-off in no time. my suggetsion if you want s-off is to use captain throwback's method rather then taco root.
and if you need help or questions then i'll see you over in the og evo root forum.....good luck.
Hi All.
So I've done this in the past but cant seem to get started this time.
I'm trying to understand the process for 3.16.651.3 / TWRP. From the instructions and use of these, it seems like I need one before the other and vise versa.
Following the instructions to S-OFF on : Unlimited.IO
It says if i have: 3.16.651.3 do Steps a - f below
If you are running a mainver below 3.16.651.3 please continue to Step 7
  1. Install TWRP (other recoveries with working sudo ./adb might work) - We cannot help with this step!
but then when I go to : TeamWin Projects - TWRP 2.5 - HTC Evo 4G LTE | TeamWin to get the TWRP package, it says:
Note:
You must be S-OFF or have taken HTC's unlock to use a recovery on your device!
I tried to do the instuctions on installing the TWRP from this thread and issuing:
sudo ./fastboot flash recovery openrecovery-twrp-2.4.1.0-jewel.img
but getting an error:
sending 'recovery' (7936 KB)...
OKAY [ 1.268s]
writing 'recovery'...
(bootloader) signature checking...
FAILED (remote: signature verify fail)
finished. total time: 2.001s
So what am I missing?
I read over these a few times, but cant seem to find what I am missing.
Any help would be great.
Thanks.
Ok... I think I'm good at this point.
I just ran RabiesShot and it seems like it got to the end but my card is 32 gb and it says not compatible.
Any way to get this to work with the larger card?
Thanks.
Thanks.
what does the error exactly say? i have a 32g card running on my phone and it has no issues.
The exact error I dont reemmeber, but it said that the card was incompatible; 2-16gb only, quiting install (or soemthing similar giving me the indication the RabiesShot failed.
I changed to a 4gb card and then the racun succeffuly broke into my house and ate my peanu butter and other items in my fridge.
Seemed to work ok then.
Can i just switch the cards?
Also....
I wanted to use MeanBean, but it seems there is an issue with fapple (what is that?)
Should I continue?
And now.....
Just went to install Titanium Backup and it says I an not rooted. I assume this is because I didnt run the 'Flash the SU file' or a ROM yet. (I was following a video to MeanBean and this was one of the steps - to install and run TiBkup)
S0ory if I'm all all over the place, just trying to get all my questions in :)
Thanks.
Also....
Should I continue?
And now.....
Thanks.
thats ok if you are all over the place, after all you are chasing that damn racun!!!!!:D
hmmm you know i did not root the phone with my 32g card. i bought after it was rooted, but i never heard of that before.....interesting. i think you should be fine using the card now though.
fapple is app association that came about because of apple's lawsuit with samsung(i think). lets say you get a text message with a youtube link. instead of opening the youtube video in your youtube app the phone will automatically open the video up on your web browser. now what fapple does is that it will allows you to open the video up in your youtube app like it was supposed to do......so you can thank apple for this.:mad:
here is a link about fapple:
http://androidforums.com/evo-4g-lte...re-app-associations-mod.html?highlight=fapple
so if meanbean has issues with it then that will be up to you if app association is important for you or not. many here use meanbean with no other issues......so up to you.
and lastly titanium backup(tb) does need root permission in order for it to work. now if you are only on stock then yes you will need to flash the su file. or if you flash meanbean then you do not need to flash su as it has it cooked in.
Thanks
Thanks.
Thank you !
Thanks.
Cool. All set with MeanBean. Had an issue with Mobile Data being Disconnected. I restarted and shut down and it seems to have gone away. I think I had this issue once before, before I did this a few months back, and tried to use Wifi. Same thing this time. But I've etsted again and it seems fine now
Hopefully things will run smoothly and I can get my contacts and such synced up now with BirdieSync and be all done.
I'm sure I'll be back, btu thanks for the docs! Excellent work.
Thanks
Thanks.
Thank you !
Thanks.
well thanx for all that thanx so that deserves a thanx;):D
and just an fyi, if there are any issues that you run into, one of the easiest troubleshooting is to go into recovery and wipe dalvik cache and cache and reboot the phone. this should fix most bugs or issues.
i'm glad you got meanbean working:)
Does the stock htc keyboard have the voice input anymore?
I cannot find it anywhere. On the stock setup, i was able to have ti above th e'.' and show up on long press.
HTC keyboard...
Microphone below the Z, if that's the question?
