OK so thanx needs to go out to beaups and fuses. If you did not know, the latest OTA (firmware version 3.17) was not rootable(no s-off).......until now. thanx to rumrunner s-off we now have root again for the latest OTA.
just a reminder that you should never accept an OTA, especially if you plan on rooting your phone. this habit should be applied to any device.
anyways here is rumrunner:
first off i will not be doing a play by play as it is better if you follow the devs instructions and not mine, since they know best....what i will be doing is just giving you an overview in the hope that it will make it easier for you to understand what the devs wants you to do.
ok so here are the prerequisites:
- this will only wok in either linux or windows.
- virtual machines are unsupported
- if you are on windows:
- have the latest htc drivers
- no htc sync(it needs to be deleted)
- any program that needs to communicate to the phone...no pdanet and such
- disable all internet securities and firewalls
- a working internet
- usb debugging turned on
- fastboot disabled(settings/battery/uncheck fastboot)
- make sure not to have any passcode or patterns for lockscreen
- use usb 2.0....there is connectivity issues with usb 3.0
- must be on 3.17 software and firmware versions
- you must be unlocked....please HTCdev for instructions
- you must be on a stock sense rom or run the risk of bootloops or worse
ok so here it is:
1.download the correct file for the htc evo 4g LTE.....there is two....the first one is for linux, while the other is for windows.
2. extract the file as explained in the guide
3.run the soju.exe
4.accept the terms and conditions
5.Congrats!!!!!!!!
now this will give you su and busybox so there is no need to do that as described in chapter 4. if you want you can stay on stock after running rumrunner, but you will still need a recovery so proceed to the next chapter.
here is the xda thread:
[s-off] rumrunner s-off - xda-developers
and here is the actual site:
http://rumrunner.us/
