CaitlinCatone
Member
Paste it to the top layer of the sd card filesystem.
There's no sd card option listed in any of the folders
EDIT: Someone's post made something that should've been obvious to me dawn on me: Make sure to enable USB debugging on your phone by going to Settings--->Applications--->Development. Also, you *may* have to change directory (cd) in command prompt if you have never used adb commands, after you have it seems at least for me you never have to do it again. Also, on step 14 I mistakenly say "reboot recovery" and while it won't harm anything, it isn't necessary to type/paste "recovery". Also, someone mentioned to me that they had to type "adb reboot recovery" after pasting the "...echo" command (step 13). Though you can try that if you have a problem, I really don't see how it worked since when you are in the adb shell (# in front instead of C:/... directory) it doesn't recognize "adb" as a valid command anyway.
**If you just need the commands and don't want to read thru the guide: Continue to scroll down, making sure to download the necessary files, to the button that says "show" for all of the commands you use, in order.**
Password for ROM: one.three
Attachment 34568 Superuser
Attachment 34569 Recovery
Attachment 34571 Su
ROM
BTW, for those people who say to go to mounts/unmounts and format system or wipe data/etc...I did NOT do that. Doing that screwed some things up for me personally, I don't actually suggest it. But go right ahead if you don't trust me, since I'm new.
I understand that these directions are already on this board in some form, but I've "consolidated" them, re-written them and have tried to simplify and explain better to the reader what is going on to help them learn what they are doing as well (give a man a fish, he'll eat for a day...that sort of idea) Two of the three files I mention are attached (superuser apk and Recovery.img). The ROM link is here and the password is one.three: one.three.zip
I'm attempting to give proper credit here from two of the places I consulted for my root. Otherwise I've used bits and pieces of knowledge/commands collected doing research on this phone and Android OS.
http://androidforums.com/avail-all-things-root/566407-root-zte-z990g- merit-avail-variant.html , [ROM] one.three [kernel1.0 included plus video fix] (update Apr 12)
First, I have directions for rooting. Next is how to flash the recovery. Finally, how to install a new (better) rom that is att, NOT straight talk.
TO ROOT
1. Make sure you have adb tools installed. Connect your phone and have it powered on, do not have usb storage turned on. It may be best to restart your phone completely and start fresh. Also, download the following files and unzip, placing somewhere you can keep up with them. Place the file called "su" into your adb "Tools" folder. I believe it is usually somewhere like: program files/android/android-sdk/tools
Attachment 34568
Attachment 34569
Attachment 34571
2. Open a command prompt box
[put Android SDK to your home folder]
3. To initialize everything open a terminal, type
cd android-sdk-linux/
cd platform-tools
./adb shell
press "enter"
4. You should get a dollar sign.
5. Now, you need to make two folders by copy and pasting these commands: (don't type what is in parantheses!)
mkdir /data/local/logs
(press enter)
mkdir /data/local/logs/kernel
(press enter)
*Note, if these directories already exist, it's not the end of the world. I failed the first go round due to a misunderstanding of the directions and had to do it over and got "file already exists". You can still try to do this without factory resetting. If you need to factory reset this phone, I unfortunately can't find a way to send this phone to recovery mode (which is where I *believe* factory reset is) without first rooting and then gaining root access in command prompt and typing restart recovery)
6. Paste this command and press enter. This next copy and paste command will cause a dialog box to open in on your phone's screen. If you don't see it after pasting this command, press the on button and swipe to unlock. After doing this, tap the first button that says "enable".
am start -a android.intent.action.MAIN -n com.zte.emode/.logset
press "enter"
7. Paste this command and press enter, this doesn't change anything, it just lists the filename if the file exists, if it doesn't exist it will say "file doesn't exist" and if it says that, wait a minute. It may not be created instantly.
ls -l /data/local/logs/kernel/log_kernel.txt
press "enter"
8. Paste this command and press enter (it just removes log_kernel.txt, that's all)
rm /data/local/logs/kernel/log_kernel.txt
press "enter"
9. Paste this command and press enter, it creates a symlink. If it gives you an error message, that means this all has been done before. It may say "already linked" or something similar if you've already done this and are starting over.
ln -s /data/local.prop /data/local/logs/kernel/log_kernel.txt
press "enter"
10. Paste this command and press enter. I believe that this "properties" file is created when you tap "enable" on step 6, but I'm not sure. And it may not be created instantaneously. Keep pasting and entering:
ls -l /data/local.prop
press "enter"
until you see that it no longer says "file not found" and you see that the file has been created.
11. Now, press the phone's power button again and slide the unlock button. Tap the 2nd gray button that says "disable."
12. Paste this command and press enter.
echo 'ro.kernel.qemu=1' > /data/local.prop
press "enter"
13. Paste this command and press enter
reboot
press "enter"
After it reboots, once again type adb shell into the command prompt and press enter. Then enter the following commands (copy and paste is your best bet)
14. The following commands will install "su" file:
./adb remount
press "enter"
./adb push su /system/xbin/su
press "enter"
./adb shell chown 0.0 /system/xbin/su
press "enter"
./adb shell chmod 06755 /system/xbin/su
press "enter"
15. These two commands will clean up un-needed files (rm means "remove")
./adb shell rm /data/local.prop
press "enter"
./adb shell rm -r /data/local/logs
press "enter"
16. Reboot your phone by either typing "reboot" or if that doesn't work "adb reboot". You can always manually reboot. When your phone starts back up, just go to play store and download superuser or download the apk from filestube if you want.
TO FLASH RECOVERY
You must be rooted for this. I am including this because the flash recoveries that came with the clockworkmod apk (rom manager), at least the one's I tried, did not work with the merit. And the recovery that comes with the merit has absolutely no options and sucks to use! If you want to flash the version of clockworkmod into your phone, just put the Recovery.img into the root (copy the Recovery.img file to your clipboard, select copy files to/from computer from slide-down menu on phone, wait for computer to give you the option to "open folder to view files" and instead of navigating to any folder on the sd card, just paste the Recovery.img straight onto the card.) Then, open your command prompt and paste these commands:
./adb shell
press "enter"
su
press "enter"
flash_image recovery /sdcard/Recovery.img
press "enter"
reboot recovery
press "enter"
Now your phone should reboot into recovery mode.
TO INSTALL NEW ROM
If you want a really cool version of gingerbread (or I think it is) on your stock Straight Talk ZTE Merit (with the bottom scrolling thing, ability to overclock with overclock program included, and of course get rid of that tracfone startup screen and music and replace with a much more appealing and silent att android splash/startup...put the file named "one.three.zip" on the root of your sd card (same way you did the Recovery.img).
Next, open up command prompt and type
./adb shell
press "enter"
reboot recovery
press "enter"
It should reboot into recovery, use side buttons to navigate to "install zip" and then choose zip to install and navigate to the option to install one.three. It will take around 5-10 minutes to do this. After it's done, it will tell you it's successful and you will be able to scroll up and down the menu with the navigation keys on the side of the phone. Just press the back arrow key, navigate to "restart" and the phone should restart with ZTE star logo then switch to the AT&T think possible logo and then an animated "Android" logo. It may stay here up to ten minutes during the first boot.
You're good to go, enjoy exploring!
Here is the OP's guide with the format fixes for linux operating systems :
Again place the su file into the platform-tools/ dir NOT tools/
Hope this helps somebody
Ya know, if you install the SDK to /usr/local/ you don't need to cd to tge directory. I run Peppermint 3 (Ubuntu 11 based) and can run adb through any user folder, and probably some root folders.
For example, I'm currently working on rewriting smali code (java). My terminal header "anthony@anthony-ACER ~/apktool $" is what I start with in the terminal. All I need to type is "adb push framework.jar /system/framework/" to push the new jar into the system.
My .bashrc only refers to ~/bin, which has my rle and boot.img tools.
Not for the Merit, but I have a bunch of stuff for the Avail. I use guake as well and have it set to alt+g.
I'm confused about what you are saying. Did you turn on mass storage & paste it in the F: window? Then turn off mass storage & go back to the SDK tools to run the commands in cmd?
