airtioteclint
Android Expert
Hmm.... could you try taking some pics with flash on and see if it freezes and gives an error?
Just did. No problems here. I'm running build 13094. (nov. 19)
I only wiped cache, and dalvik. You might want to install the stable release as your base and only wipe those two on any future update.
Has the mms worked ok for you guys
I will have to try that, any good dlna apps you know of to connect to a wifi tv?
Nah, I don't.
Pictures send fine but long texts won't. Yesterday I tried to send a color note memo as mms and it failed. Had to revert to stock to get that done.
Thanks I mean my issue has been the same with all roms getting separate threads on mms people send me they don't stay in one conversation![]()
Does it happen with stock rom too?
Oh no only with the custom roms
Just flashed the latest update on cm10 and finally my mms is fixed yohooo
Thanks cm10 guys and all the dev support here really glad to have this fine community
So where do we report problems.
Fpse doesn't work. Gives some kind of usb storage error when loading games or bios and locks up. It works fine on BlackBean rom.
Lock Screen widgets are messed up. I added weather to lockscreen and it didn't appear. Figured maybe my owner's info was getting in the way so I disabled it. Didn't work, re-enabled owner's info and now it doesn't appear either.
I'm running build 13313.
just back up S voice and either push it to the system or install like any other app. works fine for installing; and the app actually works better on cm10.![]()
Try BubbleUPnP in Google play.
I have no problem with the ROM
is anyone else having issues with cam. Force closing when taking pics with flash on?
Thats strange because thats the one I was running, I wiped and factory reset before flashing.
I figured out what I was doing wrong, I was flashing the gapps that had the 4.2 cam in it..lol works perfect now.lol
I didn't know that gapps included the camera. Glad you figured it out I saw someone else with this problem in sprint carrier section. I'll pass this on.:thumbup:
Hi, Ok I've searched and searched and haven't found a solution to what's happening to my phone or I could be searching for the wrong thing.
Here is what's happening. I hit the power button on my phone to turn on the screen and it will be dim with a slight flicker. You can't do anything if you try to unlock it goes black, but you turn it off and on again it might come on or take a couple of tries for the screen to light up like normal then you can use the phone. Now I had someone call me yesterday and the screen was black I couldn't even answer the phone I hit the power button and the ringer stopped. then kept hitting the power button then the screen lite up and by the time I got that point it went to voice mail.
Can someone point me in the right direction so I know what I need to read to fix this?
Thanks
I flashed the Stable, but then I started doing the nightly ones.
