So truelol as beta testers we have prolly bricked multiple times but thats how we find bugs.but theres always a reset if you know what to do ;P
OK ....As much as I liked the look and feel of this ROM, I just had to remove it. I actually went back to stock and will give this phone to my wife. I picked up a Moto X (1st gen) Developer Edition instead and plan to use that as my daily driver.
Just to note it for those considering this ROM, here are the main issues that I had with it that made me stop using it:
1. Bad echo on pretty much all phone calls. I couldn't hear it -- but the other end could and it was pretty bad. I tried several suggestions in this thread to correct it, but still had the problem.
2. Low call volume. Had it turned up all the way and still couldn't always hear the other end. Didn't have this problem at all with the stock ROM.
3. I was starting to get kernel crashes a couple of times a week. I would take it off the charger in the morning and drive to work (about 20 minutes). I'd get to work and pull it out of my pocket to discover that the kernel had crashed again. Reboot would take care of it, of course, but just annoying to find it crashed suddenly.
4. Trying to get around the space limitation I was using some tricks recommended here. They worked great -- except when the phone crashed, those changes would be lost. This isn't as much the fault of this ROM, of course, but the common kernel crashes made it more of an issue.
5. The screen doesn't shut off when talking on the phone (i.e. it doesn't detect when you have your face against it). This was annoying -- especially when driving and it was dark because the screen would stay lit. You could hit the button to turn it off -- but then annoying to turn it back on to hang up and such.
So, great ROM when it worked, but just too much of a hassle for a daily driver at this point.
- John...
All software problems and can be fixed.
