GPS DO WORKS....!!! Make sure u did a clean install... Flash kernel fix... Flash latest P.A Gaaps full modular 4.4.xWell it's a darn shame I had to go back to the stock ROM due to no GPS I have verified that it also does not work in CM11 also. So at this point I am just going to use the stock rom until we can get a more fully functional rom where atleast the GPS works. Please Don't get me wrong I truly love this rom it's freaking awsome. But no GPS is a deal breaker for me sorry I can live with out bluetooth. I will keep a close eye on this rom as I will run the crap out of it when it gets a bit further. Please Keep up the Awesome job you have done on this rom DM..
7-7 FineJust debloat it yourself.
Any stuff that you highly recommend not to remove ?I always do it myself
First of all that doesn't seem to b Carbon file most likely u are with Xperion... If u remove that ur bootloader will Not b patch n u can encounter a brick... That is ur LOKI.PATCH do not remove from any of the roms that u flashAny stuff that you highly recommend not to remove ?
What is this ? (its from updater script of a rom )package_extract_file("GT.lok", "/dev/block/platform/msm_sdcc.1/by-name/boot");
and theres a GT.lok file at the root of rom
No im actually on xperion untill DM finishes his projectsya that indicates your using gts lok like kry said and if your somehow using that with carbon it could indicate why your having issues too.carbon needs the carbon kernal to work right,not the gt stuff lol.not dissing @GameTheory work just stating your basically mixing jellybean files with a kitkat port if this is in fact what your doing. thats like putting bacon in your oatmeal.idc what anyone says,bacon doesnt go with everything
