JayzTwoDimes
Member
Does this rom have a working camera for version 12b of this phone?
Not yet. You'd have to flash Hroark13's cam fix kernel for cm11 which may or may not work with this new build. If it does work it would probably be much less stable.Does this rom have a working camera for version 12b of this phone?
Alright thanksNot yet. You'd have to flash Hroark13's cam fix kernel for cm11 which may or may not work with this new build. If it does work it would probably be much less stable.
@Dm47021 Thanks a million for building this ROM. I might have never discovered the insane awesomeness of Carbon Rom otherwise. I've tried almost every aosp 4.4 ROM in existence on my nexus7 and IMO carbon puts them all to shame especially cm11.
Also, can someone tell me how to tweak the volume levels? I've seen talk of editing a sitar file? I can't seem to find any posts that show the path/to/the/sitar_file. Some help with this would be awesome.
Sure.. Its tricky to edit /etc/snd_soc_msm/ in that folder .. As far as tweaking individual items.. I am not extremly familiar yet
Here hope this helpsPage 19, post 459 shows which lines to edit with Notepad++
I am assuming the line numbers will be the same but since this is a new rom/build it may be off. Just pay attention to the headings that you modify.
Also, please let me know if speaker-phone and bluetooth work with the newest build.
Thanks,
Look at the post above this oneQuick question is there a fix for the low volume i know its been asked before but couldnt find answer
Dude you're awesome!yeah buddy, bluetooth is fixed, pairs in my car with pandora working![]()
added some awsomeness tooDude you're awesome!
Its this a new ker? Will test right away... Need heads upsadded some awsomeness toohttps://github.com/Dm47021/android_device_lge_f6mt/commits/kitkat
as in built in support for apps2sd
yes, it is the new kernel iam still deving upIts this a new ker? Will test right away... Need heads ups
yeah, i was thinking about it, add a couple smaller stepsIm on it today... By the way can you bring down gpu overclock 487 its too much when it comes to performance.
Did you wiped cache n wiped dalvik by using Data_on_Sd wipe dalvik zip . so you won't break sdhack. N then flashed the newkernel.zip..???After using this new kernel for a day I can say that performance takes a dip for the Bluetooth fix. Phone starts having massive slowdowns after a few hours not even music would play properly. Gaming performance takes a massive dip as well. On the previous kernel DM made on April 14, modern combat 4 could run from the SD card without lag but this kernel makes it hiccup.
Had to switch back to the previous kernel.
