Dm47021
Android Expert
Still working on the oc right now.. Got a bad value and no bootSend it over or tell me how to.. cuz i knw that the 12b.kdz that Sammy send me we can reach 1.5mhz.. so just bring it
Sorry but that's wrong cus im in last built newest kernel wid sd.hack running nice n smoothly.. Sorry bro... PM me to see whats going on
So its just me then. Maybe I need to reformat my sd-ext or something. I'm gonna see what I can do and if I can't get it figured out I'll hit u up.The SD hack actually doesn't seem to work with the new kernel.
Try flashing the fsck_ondemand_zip if anything is corrupted it will fix if not it won't do it. If u reformat partition make sur is as a primary not logicalSo its just me then. Maybe I need to reformat my sd-ext or something. I'm gonna see what I can do and if I can't get it figured out I'll hit u up.
Sorry to be dumb but does the vibration issue mentioned above refer to no vibration when the phone rings, or no vibration as no haptic feedback?VIBRATION IS BROKEN IN THIS BUILD, IT CAUSES THE REBOOTS / BLACK SCREENS
Both.. no vibs @ all. So we don't encounter random reboots.Sorry to be dumb but does the vibration issue mentioned above refer to no vibration when the phone rings, or no vibration as no haptic feedback?
Thanks,
I reformatted my sd-ext with aparted and now it works.Try flashing the fsck_ondemand_zip if anything is corrupted it will fix if not it won't do it. If u reformat partition make sur is as a primary not logical
Actually I still do have random reboots. I had turned back CRT animation back on since DM said that the latest build would fix the issues with it (I still keep minimum CPU clock at 486 just in case). Even some reboots when using apps, I would just press something like OK or yes, then it goes to the carbon logo and start up again. Doesn't happen much like before, just thought I would mention it.Both.. no vibs @ all. So we don't encounter random reboots.
I think it has to do with fastcharge to be honestActually I still do have random reboots. I had turned back CRT animation back on since DM said that the latest build would fix the issues with it (I still keep minimum CPU clock at 486 just in case). Even some reboots when using apps, I would just press something like OK or yes, then it goes to the carbon logo and start up again. Doesn't happen much like before, just thought I would mention it.
If anyone knows how to pull system logs, it would help out so it could show the problem.
To be completely honest though, I would even ignore these reboots just because of how good the carbon ROM is.
Nope... I have mine with fastcharger... Intelli... Gpu over clock... And running smoothly... I think is a need of clean installed....I think it has to do with fastcharge to be honest
Either way ... Black screens are goneNope... I have mine with fastcharger... Intelli... Gpu over clock... And running smoothly... I think is a need of clean installed....
Yeap.... And for me the fastcharger works amazing... I can full charge y phone within 30 minutes. Thats a +... Anyway thell me how's kernel n any other built are coming out. Im ready to test.Either way ... Black screens are gone
Soon.. Still working on a proper oc higher than 1.4.. Can't seem to get it right .. May ask gt for his?? And then I can supercharge it. Add power efficient workques and yada yadaYeap.... And for me the fastcharger works amazing... I can full charge y phone within 30 minutes. Thats a +... Anyway thell me how's kernel n any other built are coming out. Im ready to test.
Im ready.. Bring it on..1.8ghz, memory over locked to 600mhz from 533. Linaro power efficiant work queues![]()
So far so good... Doing outrageous stuff. No overheating @ all....GPU on 450 on demand doesn't stick... On performance it slows things down... I'll keep searching. Thnx bro...Brought: NEW KERNEL ALPHA1-B2
Here we go. 1.8Ghz Overclocked
600mhz Bus OC
Gpu OC 450mhz
Intelliplug
intellithermal
Supercharger Cpu Gov
**** TRICKSTERMOD SETTINGS ****
Sio iosched, readahead 512, mpdecision off, intelliplug on
If you are referring to the last screenshot he posted that was an Antutu Benchmark score@@@..DM47021 by the way which benchmark app did u used (the onevof the earlier pic)
Thank you Bro...If you are referring to the last screenshot he posted that was an Antutu Benchmark score
How's everything running ??Thank you Bro...
What's your favorite governor & I/O Scheduler for this new kernel?Brought: NEW KERNEL ALPHA1-B2
600mhz Bus OC
Gpu OC 450mhz
Intelliplug
intellithermal
I use supercharger and sio.. I will be adding moreWhat's your favorite governor & I/O Scheduler for this new kernel?
