Root [MetroPCS] [ROM][4.4.4]CARBON ROM Kitkat 4.4.4 for LG Optimus F6 [LOTS OF FIXES]
How's everything running ??
Smooth... Signal,Bluetooth, swapping ness,scrolling, No overheating (1800+ 594- both CPUs supercharger) notices 450GPU ondemand not sticking... only on performance and it make it slow a bit. I knw i run heavy media apps.. At same time...but im ok with that.. Trying to figure out how to set app kill in low memory. Last night i was working on ph and n when screen when off it got on a deep sleep for a while.. About 10mn. I did not rebooted cus i wanna to see what was next. So when i got it out of sleep mode notice it was do to low mem. So far awesome...
...Lights Built from source, working, Notification LED working aswell...
Going crazy trying to figure out how to activate the LED notification.
On another note, TBU restores my Rocket Player with everything intact EXCEPT the player refuses to find my playlists no matter what I do. Grrrr!
Use the latest ROM build, the one that has vibration broken. It should be working as you install the zip.
I'm on the opposite with trying to make it not work.
Go to system settings/carbon.fiber/ buttons/ backlight turn on light
Tbu go to device settings and allow app to sync
I'm on the model with the incompatible camera. Just wanted to note that after switching over to the newest build+kernal. The camera shows not responding error message. Force closes then plays music from music player app. The front camera still works it just force closes a lot.
I understand but did u wiped cache n dalvik cache before installed rom n kernel
Already got the music player sorted out. Thanks for the tip on TBU though. As far as the notification LED it's baffling. I have the backlight turned always on but the LED doesn't blink for any incoming texts. Not a deal breaker...I just got used to it...unless I am misunderstanding what DM meant by Notification LED is working. It flashes while charging.
I understand but did u wiped cache n dalvik cache before installed rom n kernel[/QUOTE
Yes.. I did. Just tried reinstalling to be sure. I'm using twrp. Maybe I'm doing something wrong. I made a backup of data. Wiped cache and dalvik cache then did a factory reset. Installed ROM first then kernal then lastly gapps. Restored data. Reboot. Everything works great except this camera Force close issue and occasionally the audio glitches.
it does flash for texts, just turns to green.. its not like stock where its a sudden blink tho
are yall still enjoying this phone? metro is about to kill the cdma towers in my area and im thinking about replacing my s3 with this phone
Well I'll be! I'm using chompsms and had the LED set to blue for my wife and it wasn't working. Changed it to a different color and viola! Stupids things that trip me up.
Thanks!
Installed The ROM with latest kernel and I love it.
Just one thing that makes me want to revert back to xperion is The camera only let me use the Front facing , there's not an option to use the back Camera. Any help?
Try using the google cam to see if it works... I can not tell cus i hav 10i firmware ph
hroark made a good work But the Led doesn't work, I'm going back to Xperion Now.
I really loved the ROM
Keep Up the Good Work DM! Works pretty well and is very stable.
