Root [MetroPCS] [ROM][4.4.4]CARBON ROM Kitkat 4.4.4 for LG Optimus F6 [LOTS OF FIXES]
Perfect I don't use BT or Anything this is my gaming phone but man this thing is snappy I have no gripes bout it at all .... What do u mean optimize the mem routines ???..
Also can u post link to donate again u should actually make it your SIG when u post cuz not to shit on another dev but u deserve every penny people like u , warranty , GT , krlypumaa make this phone feel amazing
Thanks man. !!
New Benchmark with New Linaro Optimized Mem routines for Cortex A15...
I flashed xperion with freedom kernel 1.5ghz overclock and did an antutu benchmark for something to use as a reference. Here's what I got.
Q:
1. Is this the most stable non-stock ROM for the F6 out there?
2. I did not see a step by step plan to prepare and then install it in the OP?
Q:
Its the most stable aosp ROM and as far as stability goes I'd say its about equal with the 4.4.2 ROMs. If you want to install it just factory reset then flash it. Flash gapps also if you want.
I just installed this rom, had been using the previous version for a while. Just like the older rom, it's running great :) ...but I have one issue
With notifications, when I swipe to the left to close them, it opens the applications instead (notifications for newly downloaded apps)
Anybody ?
That's always been like that you swipe right to dismiss left to open.unless on lock screen where u view it then swipe to the right to close it
Thank you!
All of my devices, @ least 10 or more, all close when I swipe left
This is the 1st time I have to go "right" (I even had to ask :)
Strange, can I reverse it ?
Thank you!
You can disable it ... Go to carbon fiber... Go to lockscreen ...
Go to active display and disable... Or make how would you like notification to proceeds
Hi guys - I'm having one issue keeping me from using this, I can live without BT but my problem is that as soon as I install this ROM, all incoming calls get dumped to voicemail with half a ring. It rings within 1-2 seconds of the caller dialing, but barely lasts a second and then goes to voicemail.
Stock and Xperion work fine. I'm on Straight Talk(t-mobile). Any ideas?
Get a real provider...lol nah I'm kidding I dunno never happened to me
Ha yeah, I came from Verizon but I am probably going back once my wife's contract runs out so we can save a little $.
I have been playing with build.prop file per some other suggestions but even those (ring delay, etc) don't seem to help.
tested on my lg f6, wifi does not work for me. so i went back to the first carbon rom version because i use that phone only on wifi.
