RockDorsey
I knew you'd never give up!! Lol actually I was losing a bit of faith, thought the the f6 was dying. But sweet sounds exciting man! These fixes for Mystery ROM, Carbon, or both?
Other than that, everything works fine and dandy.
No rest for the wickedShouldn't u be asleep DM
I can let you test it out.. It still needs some work, I think iam being thermal throttled because voltage is set a bit too low maybe.. Not sure yet.. It is very snappy thoWhere's the kernel I wanna tryyyyyyyy I see oc gpu !!!!
What do you mean exactly.. 2nd core is enabled by defaultHow do u enable 2nd core ?
it will plug/unplug with demandOh ok I dunno cuz when I opened that faux app it said offline
