Root [MetroPCS] [ROM][4.4.4]CARBON ROM Kitkat 4.4.4 for LG Optimus F6 [LOTS OF FIXES]
Just getting a Kernel crash error, now.
"Kernel panic - not syncing: EXT4-fs (device mmcblkp2): panic forced after error"
If I remove the SD card, it will still boot as normal, so I can still get into recovery with wiping data. Just have to pop SD in before it reboots to access the SD card. Can not get it to boot into Android, though.
Think I got it this time, had to reformat my EXT4 partition on the SD card again, for some reason. Android is upgrading, and then I'll see if my storage has increased. *headache*
*Edit*
Nope, still 1.27GB internal. -_-
*Edit*
Got it working, finally. ^_^
This hack looks really cool so I definitely want to try this out instead of using link2sd, but I a little confused...
First, how do I know if my SD card is class 10 or not. I bought a Sandisk 16gb ultra. 30/mbs of speed on the package.
Second, because I have been using link2sd I have several apps already linked to my ext4 partition. So can I backup those apps up and then move them back after I increase my internal storage?
Third and Final, how do I install TWRP recovery (I used CWM) and uninstall this hack if I want to go back to using link2sd?
Thank you for your help. My sound was not working so I had to unbrick. But I'm back on Carbon so I'm ready to try this out.
I really wanna flash this again especially because of the revamped kernel...
But the whole flash/led torch lack of support not yet being figured out...
Kinda makes it a "I can wait" thing...
It's hard...waiting.....like waiting for Xmas stuff(I guess) ..
But my non existent career as a pseudo non professional eccentric avant garde photographer will be hampered.....lol...
Been running this all day not one single black screen , vibration issue or even problems with echo or anything
So enticing !!!!.....ahhhh...
Please ...Any
ideas about how to add...our hack led support....at least for the camera...I can live without the home button disco show....
I'll test em myself if files are dev'd..
.Please!?!?!?!
BEFORE YOU DO THIS HACK IF ITS A FRESH ROM INSTALL BOOT INTO THE ROM AND LET IT SET UP ON THE internal MEMORY THEN DOWNLOAD SUPER USER AND UPDATE YOUR BINARY THEN DO THIS HACK .
You need a class 10 SD card for best results
1. Make 2 partitions on SD I used twrp to do it. Go to format SD card and make sure you choose ext 4 and choose the size of your partition this will be where you data is stored, it will then take the remainder of your ad card and make it fat32 which will be your new external SD size.
2. In twrp go to settings and check the option that says format RM RF ( something like that ) . once you've checked it back to main menu go to mount and mount your SD ext partition.
3. Once mounted go back to main menu and wipe SD ext .
4. Go back to main and uncheck the format RM rf option and then go back to the main menu.
5. You then want to flash the datacopy.zip then the data install.zip ( whatever they ate called ) in post 319 for KK.
6. After it installs reboot to system and u should be good.
Some should make a tutorial for CWM because that's what comes with this ROM.
It should be similar for CWM, both have the same options but different names. Also, it is recommended that you use twrp for the roms that run 4.4. If you need the twrp, just google it for the phone, there is a handy apk to install it onto your phone.
I'm going to try out this hack and report how it goes. Should be interesting! I think a Sandisk ultra 16gb micro-sd is class 10! Right?!
Yes that's good I'm using pny class 10 32 gb and its runs great I also used system tuner and changed it from 128 KB to 2048 KB
Im glad this memory hack is getting more use. I've been using it for a while and love it. One thing that I'd like to add though- you are gonna want a high random read/write speed which is different than the class rating. Use a good brand and you should be good. Samsung and sandisk are great. I use an ultra sandisk 64gb class 10 u1 card
Hi ksjd0414 ,
1. is hacking possible on 64gb SD ?
2. i dont understand what is "datacopy.zip then the data install.zip ( whatever they ate called ) in post 319 for KK " or can get the link of post 319 for KK ?
thanks in advance.
CARBON ROM OPTIMUS F6
About Carbon
CarbonRom is an aftermarket firmware based on the Android Open Source Project. We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Features
FEATURES CAN BE FOUND HERE
DM47021 CHANGES / FIXES
This is a MAJOR bug fix release.
*Speakerphone volume increased (be careful)
*In call Volume increase
*Blank Screen of Death fixes.. may not be 100% yet, but much less frequent
*bootlogo now complete
*Overall this is much more stable than any other aosp kitkat at the moment.
Downloads
Download_Here
thanks for making this cool ROM.
installed & working very fast except wireless auto connection bug whenever reboot and bluetooth pairing problem.
i have to wireless switch off & on to connect wifi manually after reboot.
thanks a lot !!!
I had the same problem... turns out my SD Card was not formatted correctly, I used logical opposed to Primary for my second partition.
I followed the directions here (post 301) to format it correctly.
http://androidforums.com/lg-optimus-f6/819792-proposal-theory-external-sd-storage-solution-f6-7.html
Then flashed Data-on-SD-copy then Data-on-SD-install from post 319.
Thanks to everyone for putting time and effort into this!
hi ksjd0414 !
WarrantyVoider says " first partition primary, fat32 & second partition primary, ext4.
but u are saying 1st ext4, then fat32 for balance.
no big difference on part order ?
