Make sure CRT animation is off to solve the black screensWell...second attempt was sad....
I boogered up the install...It was having black screens that led to reboots...
On top of that...I used lgbackup to back up all my personal stuff...msgs,contacts,call logs........
Yah....there is no stand alone lgbackup app to download or in carbon(I'm still laughing)....
Yah...but I was ready for the after math...
After going back into recovery I just scraped everything....installed mini kk...then lgbackup was good.....
What's the best personal poop back up app?
For simple people like me....I don't really wanna back up the whole mess..
I know I can install CARBON...I did it right the first time before the magic kernel....not giving up....
Ever made in the history of android....lolThis is a very stable ROM it dose has bugs here and there but this is the best 4.4 ROM ever made yet.
Just wanted to give some feedback. I'm getting constant black screens when I press the power/sleep button (bottom buttons just light up). I'm just recently noticing constant rebooting post kernel update flash.
I also noticed that when pressing the home button the ROM almost freezes and the app preview is a blurred image. Definitely would not recommend for a daily driver unless you want your phone to restart while using navigation.
Thanks for not ignoring this phone. Hope you can get all those issues resolved![]()
As I said before turn off CRT animation. Its my daily driver and I love it.
Thanks for the advice. That does not fix the random rebooting issue though. I think it has to do with the kernel.
this is kind of some feedback.![]()
CARBON ROM OPTIMUS F6
About Carbon
CarbonRom is an aftermarket firmware based on the Android Open Source Project. We are dedicated to fast, stable, and feature-filled roms, honesty and communication with our users, and openness with our code. We like frequent builds, with the very latest and greatest hardware support and fixes. We strive to not only provide you with the best rom we can build, but also to give back to the Android community and our fellow developers. For us, this is about creating something we can be proud of and hope you will enjoy.
Features
FEATURES CAN BE FOUND HERE
DM47021 CHANGES / FIXES
This is a MAJOR bug fix release.
*Speakerphone volume increased (be careful)
*In call Volume increase
*Blank Screen of Death fixes.. may not be 100% yet, but much less frequent
*bootlogo now complete
*Overall this is much more stable than any other aosp kitkat at the moment.
Downloads
Download_Here
Been experiencing issues with bluetooth
After several factory resets, running Dalvik, bluetooth can pair with a device, however after turning off bluetooth, it gets stuck in a loop. The only way to circumvent this is to remove all known devices from the bluetooth list and then turn off bluetooth.
Can anyone else confirm this?
i can confirm this. my bluetooth headset connected fine. i then turned bluetooth off and back on. it would no longer connect to the headset and seemed to be stuck in a loop, even after turning off again.
I had that issue but enabling it and then disabling it seem to solve it for me even when I rebootA workaround for this issue that I've been using is just to unpair all devices and then turn off bluetooth.
It seems to take its sweet time turning off, but it doesn't get caught up in a loop.
I'll be checking out logcat to see what's exactly going on soon, and if there's anything interesting I'll be sure to post it here.
EDIT:
Another issue I'm having:
Using GravityBox (latest version) via Xposed always enables the navigation bar on boot.
If someone else can confirm this is an issue with the ROM or an issue with me (is the twitching normal?) that would be grand.
Also the LED flashlight doesn't work,unfortunately.so i installed carbonrom. since i have the crappy camera i went for it and installed Hroarks fixed kernel and so far so good. it actually booted and seems perfectly functional, minus the blue tint in the front camera.
i will test today and report back with any issues.
THANKS FOR THIS ROM!
If they fix these 2 problems, I would really appreciate them. <3
Here...this is probably a stupid question, but is the new kernel on the original downloads link on the first page or...?
