as long as it doesnt conflict with account set up & welcome setting, I can try
from my experience, some apps and keyboards dont work well with LG welcome setting. either i am missing some file or library files are conflicting with existing stock files..
It's cool you're taking requests but there's no point in implementing every single request. There's 100s of launchers, music players, keyboards etc. You should consider just having a LG version and perhaps an AOSP version, at most. I wouldn't want to download a bloated ROM compromising of apps that I won't use. Same goes for themes.
bad news... i installed solo launcher as default, it boots fine but it interrupted LG Welcome setting, eventually freezes Home button and Notification Drawer
it seems like Solo Launcher's Welcome screen is to blame... before I finish the phone setting, Solo welcome screen popped up then took me directly to the home screen. i could add account later from setting, but notification drawer was frozen, home button was not working..
later I will try again and see if it happens again, meanwhile you can try below file too.
You shouldn't be asking any devs how their rom compares to someone else's. They are obviously different. Both roms have screenshots and descriptions for you to make a decision and you can always try different roms to see which fits your needs best.
reset...formatted ......installed.boot loop ..recovery on its own...repeat with diff choices..boot loop...recovery on its own ..repeat with diff choices... boot loop ....recovery on its own
reset .....format everything......
make diff choices...
boot loop.....
once again..... CWM recovery on it's own....
ran out of choices....
reset....format cache....
thought about it ....... with much contemplation.....watched the grass grow.... ...
boot loop.....
Hey folks, just your friendly Mod here. A few posts have been removed for being off-topic and for bickering. Any questions, let me know!
Let's all continue a smooth sail from here on out.
I imagine Bard would appreciate it.
Hello all. My LG Optimus f6 only has 1.27 gbs of internal storage. This ROM is 667 mbs. I don't see what all I can uninstall. To get that much free space.
No...you don't put the rom file onto your phone, you place it on your sd card and follow the standard procedure depending on what recovery you are running..
That is all you will get the 4gig internal has 2 partitions the storage is only 1.27 gig the other partition holds the operating system. That is the downfall for this phone. :-(
