Thanks... new question... I have a UHS-I 16 GB micro SD card. I've done benchmark tests of my card and the internal memory. Results are below.
Internal Flash speeds
30.79 mb/s read
11.35 mb/s write
External Sandisk UHS-I speeds
125 mb/s read
50 mb/s write
Here's my question. Is there any way to install EVERYTHING to my micro sd card?
I had an HTC HD2 that I did this to, they called it "NativeSD" as opposed to "NAND". IS there a way to do that on this phone? Again I don't want a few apps on my external sd card. I want the entire rom on the external sd card. It's ~5 times as fast!!
Thanks for this ROM. Got some quirks of course (such as some kernel crashing, requiring a manual reboot), but hopefully soon it'll be a good daily driver (it's very close already!).
Speaker phone isn't working btw and callers on the other end can hear themselves a bit.
Could you Please share which version are you using.
This info can help you getting help with solving problems you have.
i finally tried CM ....i formated,formated,formated ,,,flashed,,,
and got the coolest CM bootloop....
i left it going till i had to charge the phone...
.then went back to dana....man
oh well
is CM completely functional ...with the exception of ir and quickmemo?
i think i might have forgotten gapps...
but, i'm not completely sure it's what i want if it's not a "daily driver"
so i mighta brain farted out of being cagey over using it...but, i constantly have problems with SD issues and i'm at the point of trying anything...
does cm write to SD for installs and downloads automatically...or is there some sort of SD dance involved?
i don't exactly get what it means that SD is fused...what exactly does that mean?
ROM BETA 3 Test: Random Restarts
Random Black Screen on Wake
kernel crash when call switched to speaker
rear facing camera not working
low Coverage Signal
Great Work. Despite these bugs the rom is beautiful. runs smooth. Intently hoping this rom becomes stable.
Dude, you haven't a clue just how late you are. Read the thread.
I'm running version 5 and have no problems at all. I think it's a winner.
BTW I'm still using codingninja's build and still no lock screen o death. Or random reboots![]()
Version 5? I thought Beta 3 is the latest. What are you talking about?
